Those of you who don’t have reverse loops – in which direction do you normally run your trains? Clockwise or Counterclockwise?
I’m sure there’s a Master’s thesis in there, but I’m motivated by sheer curiosity. I notice that I most often run counterclockwise, and I wondered how many others do likewise – or not.
On my S-gauge layout, the steam engine pulls cars in a clockwise direction, while my diesel (which is elevated) runs in a counter-clockwise direction, just for variety.
On my HO gauge layout, a double mainline, I follow the C&NW protocol, counter clockwise on the outer track and clockwise on the inner track.
If I were running a single track on either layout, I would run trains clockwise, just like I did when I was a kid.
I run both directions about equally. On double track areas some times it is right hand other times it is left hand like the C&NW, Since I grew up just two blocks away from the C&NW in Chicago I thought that left hand operation was normal.[swg]
I have an 11’ x 7 1/2’layout.I run freights in both directions but usually run passenger trains counterclockwise. I have145 gate man near the station operated by the insulated track and if a passenger train running clockwise stopped at the station the engine would be on the insulated track.
I run them in both directions, with a double main I prefer the trains going in opposite direction. Now when I have 2 trains on the same main its pretty important that they are travelling in the same direction.
I have an 5’ x 16’ foot S-gauge cabinet-top layout. The steam engines run in a clockwise direction. I have five siding with seven turnouts in the inner area. This way I can switch cars, set up trains, and run the action accessories within that area. This is the slow as you go switching area.
The main line I run passenger trains like the Silver Flash, Santa Fe, and the larger steam 4-8-4’s. These trains I run counterclockwise. I have a inner and outer main line. The inner main line goes thru the town station to pick up passengers. From there I can switch them to the outer main line, which goes thru the desert valley, bridges, and mountains.
I find that the steam engines run better clockwise on my American Flyer hi-rail track with rubber roadbed with turnouts. Does anyone else notice this?
I run trains on my outer loop counter-clockwise and trains on my inner loop clockwise. However, my inner loop is a figure 8, so does that mean it is half clockwise and half counter-clockwise?
Initially, I had no rhyme or reason for running them this way; it’s just the way I set it up. Now it does since I have added one siding and have more planned.
I operate my trains in both directions. My track is circular but I operate it as a point-to-point type of layout. The locomotives usually face counter-clockwise but I use steam switchers with front couplers and a GP7 so the locomotives travel equally in forward and reverse. I do have a reverse loop, but oddly enough I really don’t use it very often. In fact, I usually have it filled with rolling stock.
Mine are conditional, being mechanical and some with keys that are not so easy to remove, I run them with the key outward (counterclockwise) so they dont catch on anything
The Blueboard Central Division of American Flyer Lines is basically a simple oval, and a much larger twisting dog bone that winds around several tables. The inner oval runs counter clockwise and the larger dog bone runs clockwise. This photo has the smaller loop to the left and the dog bone to the right. The third train in the background is just positioned for the photo which I used for a SPF some time ago and which I entitled Heavy Traffic.
Northwoods Flyer
One mainline, plus5 bypass sidings holding trains.
5 run clockwise; 1 runs counterclockwise.
Have no idea why I set them up this way, although I have discovered a derailment issue at the turnout into one bypass siding going counterclockwise, and I avoid that route.
Running in both dirrections does show where there are potential problems in the layout.
