s-gauge fastrack
can anyone tell me if the af fastrack will connect to the s-helper track? or does it agapt to the old af switches?
This is a recent thread which may help you out.
http://cs.trains.com/TRCCS/forums/t/201909.aspx
S-Helper has connectors that permit their track to mate to original flyer track. I have used them at they work fine. It is the flyer pin on one side and fishplate conector on the other to match their track, Since Lionel fast track has the same dementions as S-Helper and both are the same height as traditional Flyer track the S-Helper adapter pins should work.
