S Gauge Turntable
Hi, I have my roundhouse in the painting stages, an so now I need to find a turntable. I have mostly old AF steamers, 293’s, 312’s and a 342. I need a turntable bridge length of 16 inches. Turntables made for S are few and far between and rather expensive.
I have been looking at the Walthers Cornerstone HO 130 foot model. The bridge length is advertised as 18 7/8 inches. Has anyone converted one of these to accept flyer track? I have also considered ther Atlas O turntable, but I prefer the open pit design.
Any other turntables out there that you have used on A/F layouts?
Thank you,
George
Hi George,
Tried the HO idea but did not work, the weight of the engines, width of the track, wire routing, etc. just did not work. Try Bowser/Stewart Hobbies S guage turntables… really nice, not sure of you have the budget though, these run very high, very nice quality. I think they make one as large as 32 inches in length.
http://www.bowser-trains.com/sscale/sscale.htm
What is nice for the price you do get the motor, however if you wish to have it index, you need the electric indexing kit.
Another idea is to investigate an Atlas O gauge turntable, not sure if it meets your length criteria though.
Good luck!
I second the Bowser turntable. As long as your benchwork is stout, you get a nice firm base for precision alignment. A firm base makes or breaks a turn table. Otherwise they are a nightmare and only good for static display. In the Bowser site, I don’t see just the turntable and bridge beam sold by itself. They used to sell them this way and you could save a bit of money making your own girders.
J.daddy, John,
Thank you both for the input, you are right, the Bowser unit is awesome. I am just not sure I can justify the cost. I keep looking at the Atlas O unit, but really want a pit design TT.
I am still hoping someone has successfully converted the Walthers 130’ TT to work with S trains, and can share the experience with it. I see all of good reports on the operation of these units, but as you pointed out, I will be askign it to work much harder turning a 3-4 lbs AF steamer.
Thanks again,
George
