Sad Train Stories
This thread is for all of you who have had a sad tragedy with your model trains. Feel free to express your felling in a nice way about the accident.
I myself haven’t had a terribly sad accident.
Me either.
After our move I had a section of track up and, in a momentary lapse, ran a Proto F3 over the edge! 4 feet onto the concrete. [V] Fortunately, it’s not an expensive engine and, after resecuring one of the motor magnets, it runs like a champ. Live and learn though…
Other than that, there’s not much sad in my model railroading (or railfanning for that matter). Both are great opportunities to spend much time with my 10 year old son. It doesn’t get any better than that.
Many years ago, my first layout, with a reversing loop on a lower level. The switch stuck and a brand new not yet painted brass Key N&W K2 streamlined derailed and fell three feet plus onto the floor.
After that, nothing else bothered me much.
Had a Bachmann 0-6-0 switcher, ran like a dream until I fell behind in track maintenance, then it ended up getting dust into the motor. I cleaned it and cleaned it, but it was no good. She jerked and balked, and finally stalled. Now that little engine runs like a dream, as long as there is another engine pushing it. I had to remove the motor to get it run like that, though[V][:(] Fortunately it wasn’t brass, like Virginian’s. Real sorry about that. We all live and learn, I guess. I’m just glad I’m not at the throttle when things go wrong! At least I can escape with my life![:D]
Back in 1985 or so (when I had very little money for trains), I found an Atlas E7 in N-scale cheap at a local swap meet. This was when this was a fairly new technology. The previous owner had over lubricated and it look like ran it on the floor through dirt. I took it home, totally disassembled, cleaned, shimmed, reassembled, and properly lubricated. All told I probably spent 10 hours on it. I put it on the layout and began break in.
It ran back and forth and around at varying speeds for about two hours. It ran better than ANY N-scale engine I had at the time. Finishing, I cranked it up to full speed for a final loop or two, when something distracted me. I went across the basement and dealt with whatever it was. I turned around just in time to see the locomotive take off the main, and head up the siding. I ran and lunged for the layout control power but it was too far away. I watched in slow motion as the loco went up around the branch, through zig through three tunnles, shoot through the stub ended mine, and go flying off the 52" ledge. It landed and broke up into all those pieces I had just reassembled. Cracked the body, broke one of the trucks, bent a couple wheels.
All I can figure is the turnout (an original Atlas) slowly worked over and over as I was test running. I was devistated and didn’t have the heart to work on it any more. Its parts are still sitting around here in a box some where. I suppose that way it survived the great N-scale purge a few years later.
I had my first off-the-board-down-to-the-floor crisis last night. I’m still early in construction, and I knocked over a gondola car while positioning some foam. It was the car with the train camera. No permanent damage, though, as I’ve got a nice soft carpet down below. The camera, which is only press-fit into some foam roadbed chunks in the car bed, popped out but was otherwise unhurt. The newly-installed Kadee #5 came off as the draft gear cover popped off, but I just put it all back together after straightening the spring plate a bit. Gotta be more careful, though.
Back in 1988, I had an N scale Kato CSX GP38 go airborne.Bent the Rapido coupler
and broke two handrails. It still ran smoothly, but looked awful. [:(]
Last mounth I was running my O gauge two level layout when I spun around and hit my controller!The ran so fast I didn’t have time to trun it down and…DING!It hit the wall and knoced down some trees.No dents but lession learned.
I almost had a sad event. Will relate it here, b/c I’m sure everyone has seen the cartoons and moveis/tv shows when a car or truck or whatever “almost” goes over the cliff, and the vehicle is balanced rather precariously, ready to fall if anyone makes a wrong move or breaths funny…
I had just replaced my MRC DCC control with a Digitrax… My dad had brought over a couple of new Proto A/B units. I installed a decoder in the A unit, programmed the address and placed it on the mainline. I gave the loco some throttle, but forgot that I had thrown turnout #3 to go up the dead end siding… The dead end of the siding ending with one of the Atlas plastic rail bumpers about 1" from the edge of the layout.
Well, that loco went flying up the siding, which is only about 2’ long, and I cut the throttle back down to 0… The loco barrelled into the bumper, and sent it flying across the room. The loco ended up half on and half off the layout, swaying back and forth like a teeter-totter :slight_smile: All I could think of was how po’d my pop would have been if I busted up his brand new locos…
As npr765 said, no dents, but lesson learned!
When my now 35 year old son was a little grade schooler he and I were operating my two or three locos on a circle of track and we sent a AHM (Riverossi) Berkshire over the edge. Then about three years later I was showing him our club’s layout and we ran one of those “old time” (diamond stacker and all) AHM cheapies around the club layout and something happened, not sure what. It stopped all forward motion and the boiler melted, obviously from some excess heat from the motor. Today my son is not interested in dad’s trains.
Not much time ago, everything was going smoothly while testing the newly laid track. As part of the tests conducted, was the full speed trial. Every engine of the roster would be subject to these trials to ensure no failure. Two complete runs full ahead and two complete runs full reverse for every one. The turn came to 6319, a brand new Atlas U23B. She did fine on her full ahead test, now she was ready to take the full lenght of the layout main at full speed in reverse. Although this will never occur during operations, its the only way to be sure everything was laid correctly. She was dashing like lighting smoothly over the code 100 main line, until she reached a corssover. For some reason she derailed (then I discovered a small wire clipping inside the frog). The poor thing went airborne for about 3" and landed sideways on the floor (granite slab). At first glance, there wasn’t great damage, only the cab was detached from the hood. A closer inspection revealed for my horror the real trauma. The force of impact had crushed the front part of cab against the hood, all the plastic conforming the window frames was bended and broken. Inmediately I set up an emergency O.R. and began surgery (literally, plastic surgery). Some putty, cutting and painting was required. I even used my soldering iron to un-bend some twisted plastic parts. Now she’s fine, no permanent damage to her guts, but now she’s is known as “Scar Face 6319”
I have not been able to work on my trains for two weeks [:(] due to soccer, softball and other warm weather events.
I got myself deep in debit buying these expensive locomotives.
Ouch, cspmo, that is a tough state to be in. It can really drain the fun out of your hobby. I hope you get back on your feet quickly. [sigh]
I have a sad train story or two when I did something really STUPID but I’m sure not gonna tell it.
well, i DO have a sad train story. One time i accidentally reversed the polarity of the track wires (way back before i had DCC) and my brand new Amtrak F40PH plowed through the buffer and skittered along the concrete floor for 10 feet. She still runs like a charm, though, but i think i messed up some of the cosmetic features. On the other hand, a coach behing the engine came off the track and broke off the coupler pin (Kadee coupler), so it is consequently out of service until i can replace the coupler.
don’t use food (like muffins) for scenery, they don’t hold together very well, and the dog or cat, or kids enjoy eating the vegetation - at least until it goes rank… (I’m kidding of course). I’ve now found something better than used coffee grounds to use for dirt - actual dirt is better. [banghead][(-D][(-D][(-D][(-D]
One of my locos hit an open switch next to the edge of the track , derailed and went right over the side…Luckily the dog bed happened to be right under it, and all it did was bounce once…Wheeeeuuuuw! [;)]
Also i hate to admit but when I was a kid I used to run my cheepie Lionel trains over the tops of the stairs so I could watch them tumble down the stairs…[:0]
