Same track, different speeds?
I’m confused.
A few days ago I was leaving work and was held at a two-main CPR crossing a few minutes north of the office for an eastbound train. The locomotives had already passed by the time I got there, so I’ve no idea what motive power it had.
But it was SOOOOO slow! Now I enjoy getting stuck at crossings as much as the next guys (and a lot more than most), but I was there seriously 20 minutes.
Unfortunately, I had left my scanner at work, so I couldn’t listen in and try to figure out what was up. But then, to confound matters more, a westbound came by at normal track speed — and the eastbound was still going after the westbound left. (First time I’ve seen a meet there, though, so that was cool!)
One possibility could be that the train going east was too heavy for its motive power. But the train was primarily autoracks, and most likely empty going that direction.
Any ideas? Curiosity may have killed the cat, but it employs the Kathi. (Just be very careful, Mookie. Curiosity never kills careful kitties.)
Thanks!
Kathi
I would suspect that you ‘slow’ train was a victim of engine failure…Had enough power to keep moving on the territory…just not enough to move at a reasonable speed.
As all railroaders know…Engine failures do happen!
BaltACD raises a good possibility, and I should not venture into such treacherous waters with my limited knowledge, but:
I don’t think BaltACD’s answer is correct. The way Kathi described it, the train was going extremely slow. If the engine were struggling with a load at that speed, wouldn’t there be overheating problems?
My only explanation is that it had a red or yellow light in the next block and was traveling at a speed that it could stop at the light? A problem with a particular car might also be an explanation.
BaltACD, please correct me if my analysis is faulty, I don’t know that much about traction motors.
Gabe
BaltACD’s probably right. However, there are other possibilities, any of which would not affect a train on the adjacent track:
–slow order on that track (you have to think that trackwork was not being performed, otherwise the train on the other track would probably be slowed, too).
–following another train
–signal failure
–moving slowly in response to a defect detector (is there one anywhere around?)
So many possibilities!
I know the spot Kathi speaks of, most likely the slower train was running in an occupied block (ABS) at restricted speed. East bound was right on the heels of another train. Trains are often held at Grand Ave. for a yard track to open up. and sometimes trains coming out of Muskego yard are crossed over at the old cut off.
Randy
Thanks, guys, for the help. That’ll teach me to leave my scanner behind for even a night.
Randy, thanks especially for your insight on the area. I wonder why traffic was so heavy? Typically, I see a westbound headed toward me around 6 or so, and the only eastbound I’ve seen has been the Empire Builder around 4 or so — if I happen to leave work that early. But there’s been a lot more traffic here lately. If the weather were a little nicer I’d have to take advantage of that.
Either way, it looks like I’ll be seeing you in spring.
Take care!
Kathi
Minimun continuous speed for DC engines ranges from 9.0 MPH to about 12.0 MPH…both of which, when waiting on a train to pass a point are interminably slow.
AC engines don’t have a minimum continuous speed…AC motors can creep along at a snails pace without overheating (at least in theory).
could have been a tempory speed restriction put on by MOW for that train only…like a broken rail that was being repaired…and the first train over it is to go walking speed or at a set speed restiction to make sure the rail is ok for main track speeds by the following trains… also…the train could have been running on a “bad” signal…running on a restricting… also…a train ahead of it might have gone into emergancy at some point near that crossing…the next train past normaly runs at resticted speed from the point where the train went into emergancy and to the point where the head end of it stopped…this is done to make sure the track is ok… befor following trains are alowed to run at track speed agin…
csx engineer
This is perhaps a little off-topic for this thread but not for the general forum. A big problem of this slow train tying up the grade crossing is the “crying wolf” effect.
We talk about how the general public are such complete idiots when it comes to grade crossing safety, but when you tie up grade crossings with slow moving trains like that, you create an incentive for folks to break the law and try and beat the gates or go around the gates (after all, the trains are slow, or it is some switch engine that keeps tripping the gates) and then the fast train comes through and bam!
I am sure the railroad has some operational reason for running that train slow as well as some safety reason, but tying up a grade crossing has an effect on degrading safety as well.
Mark Hemphill: I don’t mean to take the trial lawyer approach and say that individuals have no personal responsibility to protect themselves and that anything bad that happens to anybody is the fault of some corporation with deep pockets. And I hope I wasn’t encouraging anyone to ever drive around crossing gates – not only illegal, a highly dangerous activity. And there are often reasons for things to be a certain way, and us “amatuers” and “Monday morning quarterbacks” are wellsprings of advice that isn’t thought out.
On the other hand, transportation of all modes is a social activity in our densely-travelled world and requires social cooperation for all parties involved.
How about if I leave railroads out of this. I got back from Philly – attended a scientific conference – and I was in the company of a colleague who introduced me to a graduate student who was travelling between Pittsburgh and Philly to locate medical patients with a rare combination of conditions in order to recruit them for a scientific study of that situation. The student talked about the risks of driving in the bad rains from the tail ends of the spate of hurricanes this year. My colleague added “oh, and I bet the Pennsylvania Turnpike always has construction on it.”
Now road construction is a fact of life, and we all grump about it but if it doesn’t get done we won’t have any roads to travel on. And motorists drive to fast in construction zones, and this is also illegal and highly dangerous to crews and motorists alike, and technically it is all the fault of the impatient motorists, but do you suppose the people who plan road construction have a tiny-tiny role in any of this? Now I am one of these amateur-experts and have driven through many road construction zones on German and Austrian Autobahns. These zones are short, there are a slew of signs progressively slowing the speed limit and cutting out lanes, and there is a law in Germany that drivers are to take turns (one car from one lane, a
[quote]
Look, we cannot make Americans into Germans. Nor should we want to. A certain amount of rough edges and conflict is built into every society. Including Germany, but it just shows up in other areas. The New York Times occasionally gets a bug up its … and goes on a tack that has little relation to reality. Sure the UP makes mistakes. But the vast majority of the grade crossing happenings are drivers’ faults and not the railroads’. For the Times to blow up a minority of incidents is simply unfair.
Ad of course there is my old schtick: We wouldn’t have near the problem if the highway lobby-oil-auto people made SAFETY, rather than gas-oil-auto SALES, their main goal.
Railroads are also interested in making money. But they have a far better safety “culture” than the highway-auto-oil people. Otherwise we would have computers on cars that relate to wayside and to other cars in ways that reduce accidents. The technology has been around for a long time and would make a small incremental addition to the cost of the typical automobile. But even then of course we are all only human beings and yes railroads have also made safety errors.
