[#welcome] to the forum. Your initial posts are moderated and therefore delayed.
The link you posted is for some other poor departed soul, not Ralph Marcus. A google search comes up with several past auctions on ebay as well as a link to a Train Order Office designed by him in Jan 94 MR.
Howard Zane is one of our forum members and very active in brass in that time frame. If he draws a blank, you might contact Brasstrains.com.
See item specific comments at bottom of following ebay auction link:
There seems to be some unusual detailing on that locomotive, such as the cross compound air pump, apparently doing duty as a water pump.
The cord for the front mounted bell is another oddity on what appears to already include an air-ringer. Besides that, the amount of slack in the cord would require the operator to coil several feet of it on the cab floor before it would be taut enough to actually ring the bell.
I think somebody’s spoofin’ somebody.
I’m far from a steam guy, but did they actually do stacks like that? Pointed back at the cab? [:^)]
Mike.
Admittedly, the photos are pretty dark but I’m not quite seeing the Westinghouse Cross-compound “water pump” ??
The actual 3759 does have a bell cord but, of course, it is much finer than reproduced on the model.
https://commons.wikimedia.org/wiki/File:Kingman_Santa_Fe.jpg#/media/File:Kingman_Santa_Fe.jpg
It shows up better on this photo of the 3751:
https://commons.wikimedia.org/wiki/File:ATSF_3751_19920000_IL_Streator.jpg
regards, Ed
Maybe it’s not a stand-in for the water pump, but that’s the first time I’ve seen a cross-compound air pump underneath the cab. I’ve seen them above/ below/and blocking the running boards on both the fireman’s side- and the engineer’s-side of the boiler, mounted on the smokebox front, or on the deck of the pilot.
I have seen that style of smoke deflector, but seem to recall it as being for use in particular locales…perhaps unlined tunnels or where the track passes under certain bridges. IIRC, it’s air-activated, so used only when necessary.
OK, NOW I see it (wasn’t even looking there!) yes, that space is usually taken up by the stoker engine. There’s a second air pump behind the shield ahead of the left cylinder and on the other side of the pilot, the Worthington feed pump.
https://sfrhms.org/wp-content/uploads/2019/02/stack-extenders.pdf
I seem to recall the UP using another type that colapsed like telescoping shells.
More oddities here, including some with ductwork all the way back over the cab!
http://www.douglas-self.com/MUSEUM/LOCOLOCO/chimney/chimney.htm
Regards, Ed
I dunno, Ed, but I think it’s maybe a Franken-Loco. The Worthington system uses two pumps, one for the cold water from the tender, and another for forcing the heated water into the boiler. In most cases, the cold water pump was on the fireman’s side, under the cab, and usually lower than the bottom of the tender. In many installations, the hot water pump was also on the fireman’s side of the loco, usually just aft of the valve gear, although I have seen ones on the pilot deck, too.
I guess pretty-well any railroad had its own peculiarities, but these seem almost contrived, at least to my eyes.
There are some oddities on there for sure.
This is the Worthington SA pump that I thought I could see behind the shield on the pilot:
Worthington_HW-pump by Edmund, on Flickr
Lord knows where the cold water pump is?
Worthington_turbopump by Edmund, on Flickr
Sure is interesting to try to get into the minds of the designers and attempt to understand what their goals and aims were. Back then you just didn’t buy a locomotive out of a catalog. Every Superintendant of Motive Power had his reasons for designing and specifying everything from knuckle-to-knuckle.
Cheers, Ed
Yup, that’s the hot water pump. I added one (a Cal-Scale casting) to this Bachmann USRA Light Mountain (under the running board and above the valve gear hanger…there’s a flaw in the casting that looks like a dent - I should have filled it)…
Here’s the cold water pump on mine (right below the leading edge of the firebox), and based on a photo of a real locomotive thus equipped…
I have to agree: it looks equally as odd as the real one, although that bell pull-cord is distracting on the model.
I finally found a decent shot showing where the cold water pump is hidden!
atsf_3759_crop by Edmund, on Flickr
Regards, Ed
Ed, your resources regarding almost anything continue to amaze me.
I can’t imagine modelling the detail in that photo,and still being able to get any room for that trailing truck to make it around a curve, no matter how wide the curve might be.
Hi BigDaddy, I appreciate to you for your kind and useful information, and I hope Howard Zane can see my question and provide me about Ralph Marcus. Thanks.
Looks like a lot of you “learn something new every day”! Ain’t education fun!
Hi everybody, I appreciate to you for your lot of responses. Although I don’t know about the AT&SF 4-8-4 very much, I feel I had learned a lot through your discussion. Here I searched the AT&SF 4-8-4 information through Google and I found many different original types and their photos of AT&SF 4-8-4 in Key Model Imports official website (http://www.keymodels.net/id23.html).
Well one big clue in your post is your mention of the Santa Fe historical society. so I went to an on-line index of the articles in the various versions of their magazine over the years and found that Ralph Marcus wrote several articles for them on steam locomotives, rolling stock, and MOW equipment. Perhaps all from the modeling perspective, I do not know. It stands to reason that someone active enough in a society of that sort to enter and win modeling contests is likely also a contributor and known to the society.
https://sfrhms.org/wp-content/uploads/2016/06/webtitle-index.pdf
Then a google search for “Ralph Marcus” “Santa Fe” turned up all sorts of references of locomotives he built or detailed, including other ebays, and one that says he was from California. Unfortunately it also turned up a 2008 Santa Fe Modeler’s event in Quantico VA that includes in its agenda “A Tribute to Ralph Marcus.”
Combining “Ralph Marcus” “Santa Fe” “California” and “obituary” in one google s
