In the spirit of “Philiosophy Friday” tell me about your tunnel(s).
The reason this subject has leached in to my tiny mind is because a fellow model railroader that I know has seen things my way. He has started the task of removing some tunnels on his layout. When he began his layout and asked what I thought, I suggested that with the amount of time his trains will be spending inside tunnels, it will seem like there are no trains on the layout for our eyes to feast on. He is still tunnel crazy, however he also wants to actually see his pride and joys in action.
I have two tunnels, one about 18" and the other when finished will be about 3’. The 3’ one was an after thought, it gave me a place for a small town I wanted but didn’t know where to put. There are lots of places in the world where the railroad goes under the cities and towns.
So Saturdays survey question is… How many tunnels do you have on your pike and how long is your longest tunnel? Do you go for lunch, knowing the train will emerge about the time you get back?
I have six, the longest of which is about 4’. I just ‘daylighted’ one because of access problems. The others are to either hide return loops or necessitated by scenery concerns. Actually, what I have more than anything on the layout is bridges. I’m a bridge freak, lol!
I have one two tunnels. There is a coal mine that sits on top of it and the mine operator wouldn’t be too happy if I dynamited the whole thing!
Daylighting tunnels has been practised on the 1:1 railroads whenever practical, sometimes at great expense.
Part of my reason for a tunnel is to allow the train to disappear from sight for a while then reappear in a different scene. It helps to eliminate the “spaghetti bowl” effect of watching trains run as if on a race track. I have a sliding panel on the side of the fascia if I need access for track cleaning or rerailing. There’s also 2 video cameras watching the track in there.
I have two double track runs through the mountain with a combined trackage total of about forty feet of track.
I like having the scenic interest of the tunnel. All my rides on the old B&O and Pennsy, even the Wheeling & Lake Erie and N. Y. Central all included tunnels.
Here’s a view of the coal mine, with one of the double track lines shown in the foreground, come to think of it, that would count as another tunnel to the right. There’s also another main line loop under there.
I think tunnels are great if you can justify one… Ed
One, about 20 inches (of a 2x16’ layout). Its the portal to staging. If the layout ever gets fully built to spec, it would probably reach close to 60 inches.
I will have five: one 6" to 8"; two about 18", one 2+’ and one about 4’. Plus two tunnel portals leading to an adjacent space for two storage & reverse loops. These will be open in that unfinished space but unseen from my train room. The train room tunnels will cover about 15% of train room main line.
I have two tunnels on my layout. the Gallitzin Tunnel for the two west bounds tracks and the New Portage Tunnel for the east bounds tracks. Just like the prototype.
I’ve got 1 tunnel. It has an 8 foot long oval with a passing siding, a single-track spur and a double track siding off to the end for train storage, signals and 4 stations. There are 4 portals.
It’s a subway. First I built the subways, and then I put a layout on top of them.
I think there’s a distinction between in and out tunnels along the line and entrances to staging. I only have one in and out tunnel. It part of a turnback curve under Animas Forks that takes the lower level track to Red Mountain
I have one more tunnel portal, which is really only the entrance/exit for RGS staging west of Durango. The other end loops around to come in on the south side of Durango under an overpass to form a continuous run loop for HOn3 break-in and testing.
Then there is staging. My standard gauge is a giant folded dogbone, so the back half is underneath the narrowgauge upper deck along three sides of the room. My Chama staging for the NG is entirely hidden once it goes under the highway leaving the south side of Durango. There’s also a loop that connect Red Mountain back to the wye at Silverton. So literally doezens of feet of hidden track. I miss seeing it, but I wouldn’t have been able to pack everything I have if I’d done without. The next layout will likely see a much lower % of hidden track. This has been a relatively trouble free installation, because I took great care putting it in, but it’s better to have as much out where it can be seen as possible.
My longest ‘tunnel’ covers about 60% of the loop that is the JNR’s first main track, serves five different kinds of staging (all having additional track) and, officially, doesn’t exist! Two of the tunnel portals are on the Down main, the third is on the Up main and the master map says that the main doesn’t connect back to itself. The only time anything orbits is when I am running in a piece of rolling stock.
I have four additional short (>1 foot>) tunnels, and one longer (4 foot,) on the JNR main, simulating what my prototype had. If you run up a canyon that has spur ridges and side ravines, tunnels (and intervening bridges) come with the territory.
The Tomikawa Tani Tetsudo also has several short tunnels, two of which hide one-turn loops and are longer than they look. The prototype, the currently unused end of the JR-East O-me-sen, was built through what can only be described as broken country.
And then there’s one tunnel that won’t connect to anything. When I build it, it will contain a working tunnel boring machine.
Most of the length of most of the tunnels can be accessed by removing lift-offs.
Because I consciously chose to model a prototype that needs lots of tunnels, having them doesn’t cause any heartburn.
