Sausage Tender
Some of you may be aware of a tender style known as a “sausage” tender. The one I’m most familiar with is in what used to be the Age of Steam museum in Dallas–museum has a new name now that I don’t recall. The tender is on a Baldwin 0-6-0 S-12 that was the yard goat at Dallas Union Station into the early 1960s.
The only model of this S-12 that I every ran across was a Sunset brass made in the 60s or 70s. Question is, does anyone know of any other model of the S-12 that is more likely to turn-up than this rare brass model? More to the point, is anyone aware of a model of just the sausage style tender that has been made? I can probably find an 0-6-0 that will work, but scratchbuilding a tender like that is beyond my skill, and patience, level.
Any ideas?
Mike
Unless you´d like to settle for something like this:
Sunset´s brass S-12 is the only one I know with a sausage tender.
The correct terminology would help your search. I think you’re looking for Vanderbilt tenders?
http://www.google.com/search?q=Vanderbilt+tender&hl=en&client=firefox-a&hs=lWT&rls=org.mozilla:en-US:official&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=lOHlT9PGCIqJ6wGEo9zfDg&ved=0CIABELAE&biw=1333&bih=858
Some railroads favored this design is about all I know. Not sure what the advantages vs disadvantages are compared to other tender designs.
If it’s actually made of sausage, then don’t go cheap and greasy. Get the good brats…[8D]
Mike, sausage tenders are a different animal than Vanderbilt tenders - they lack the “coal compartment”.
Yes, the ‘sausage’ tender is not a Vandy tender. I’ll post a photo if I can find it in my library, On-line search turned up a good number of tender sausages, but not sausage tenders.
Mike
And here I thought somebody was anticipating the transition to LNG-fueled diesels, with a `weenie on wheels’ tank between two six-axle behemoths.
(And if it derails, how do you model a scale BLEVE?)
Chuck (Modeling Central Japan in September, 1964 - with diesels that burn diesel)
If that’s what we’re talking about, it might also be called a “tank” tender?
I’ve just never heard the term “sausage” tender – but the older I get, the more I realize there’s a lot I don’t know. [*-)]
The one pictured represents a later SP modification to increase oil capacity, note the raised bunker and walkway handrails. I believe most if not all had this work done. I suspect one could use a tank car as the basis.
Dave
Now I’m hungry.
Here is a photo of the tender. It looks to be the same as the photo Jeffert-Wimberly posted. All references to the locomotive in the literature about Dallas Union Station refer to it as a “sausage” tender, as does the reference to the Sunset S-12 model in the Brown Brass Book. Now the question recurrs—anyone know of a source for a similar model or, for that matter, an available Sunset S-12?
Mike
:http://texashistory.unt.edu/ark:/67531/metapth28800/m1/1/?q=dallas union railroad terminal:550:0
I never sausage a frank discussion in this forum before. [:-^]
Just making that a clickable link.
Looks like Balboa may have made them at one point. There is one on Ebay now.
http://www.ebay.com/itm/HO-Scale-SP-Class-S-12-0-6-0-by-Balboa-/320925951980?pt=Model_RR_Trains&hash=item4ab8ad67ec
Stevenson Preservation Lines makes one of these tenders, but unfortunately it’s O scale.
Then enjoy another link! [swg]
http://stevensonpreservationlines.com/product_info.php?products_id=
I would assume it’s an oil tender, right? at least it’s better than being called a “wiener” tender.
Bachmann makes some small vandy tenders that possibly could work for a kit bash. They’re only about $15 at Trainland. I’ve only seen pictures of them so I don’t know anything about the construction (or destruction). Just a thought"“…”…
