This is not a post about “which is better, HO or N”.
I just wanted to get that out of the way so the thread doesn’t turn into that.
I’ve got a dillemma. I have space of approximately 126" x 106" (10’6" x 8’10") in my new house. This has been allocated to me by the Person In Charge so I’m all good there.
Now, I’ve previously done HO. I love the scale it balances detail with action. Standard 4x8 stuff previously and a coupel tabletop designs. With the new space I originally intended to do an around-the-walls shelf layout in N scale. I have even gone so far as to lay out the basic benchwork (L girder along the walls). The track plan has been in flux but that’s the wonderful thing about L Girder, you can “make it fit”.
Here’s my problem now. I was downstairs tinkering with a little SW8 N scale loco trying to get the shell off to see how much work it would be to get a decoder installed. I’ve done side-by-side comparisons with N vs HO before and found that the “look” of N scale worked for me. I was excited because it would allow me to pack a lot more into the limited space I have.
After finally getting the shell off I realized - holy COW are the parts small! I’ve got fairly nimble fingers and I’m 37 with good eyesight but boy was I having trouble keeping things together.
So I started to second guess myself. Going with N basically means I’ll be sacrificing sound (mostly), and will be living with a visor on my head to be able to see everything. On the flip side I’ll be able to do “more” of what I want to model (eastern pennsylvania modern shortline with coal).
So here’s basically what I’m asking the masses - and yes, I know the final decision will be mine but I’m hoping to get alternate viewpoints - is the space I have enough for a (scaled down - no pun intended) layout that wou
