I am building a large Trestle. Is there a Web Site that gives you all the conversions of Actual Lumber sizes to HO scale? If not, what is the formula for this conversion. Thanks in advance for your replies.
If you have a calculator its not too hard.
real size / 87 = scale size
For example
14" / 87 = 0.161" (in ho)
12" / 87 = 0.138" (in ho - .013" over 1/8")
Some vendors sell strip wood in actual HO sizes.
Regards,
Charlie Comstock
http://www.kapplerusa.com/y2k/p-ho-12.htm
Here’s a site with size charts in case you hate math…[;)]
The formulas are:
For conversion from inches to feet or inches in HO:
(inches/12) x 87 = feet in HO
For inches (less than 1 ft.) multiply the above answer times 12
You can set up a conversion chart on Xcel using this formula.
I generally use rulers that measure in tenths, rather than 16ths or eights of an inch; this makes things a little cleaner.
I hope this will help
