Most of the posts have identified the important points. To measure speed accurately in the locomotive with DCC, the following have to occur:
the decoder must use a tach or cam on a drive axle, and have a time base. Or if using BEMF or a flywheel tach, must have a time base, and “know” the gear ratio.
the decoder has to have a way of transmitting the speed info through the rails back to the DCC system
the DCC system must be capable of understanding the speed data packets and displaying them appropriately
AFAIK, this would all be outside the NMRA DCC spec, and thus would be a proprietary extension. This means the chances of different brand decoders having speed read by any given DCC system is not high.
Without setting up a speed measuring section of track, or pulling a speed measuring car, you can estimate scale speed within 3-4 MPH by counting cars passing a point in 5 seconds. This works much better if you cars are fairly consistent in length and some reasonable divisor of 12" in actual length.
60 smph = 10 6" long cars in 5 seconds (HO 40ft box cars are 6" long)
9 cars in 5 seconds = 54 SMPH
7 cars in 5 seconds = 42 SMPH
5 cars in 5 seconds = 30 SMPH
4 cars in 5 seconds = 24 SMPH
3 cars in 5 seconds = 18 SMPH
2 cars in 5 seconds = 12 SMPH
1 car in 5 seconds = 6 SMPH
Note how slow a realistic switching speed is - one to two 40ft cars passing the turnout frog in 5 seconds.
A steam drag freight over a grade would be 2-4 40ft cars passing the summit marker post in 5 seconds. A train of 20 ore (4" long) cars should take at least 30 seconds to pass that summit marker.
A loop on a 4x8 typically has about 20ft of track. A train at 30 SMPH should take 40 seconds to go around the loop.
I dare say very few of us consistently run at realistic scale speeds. We tend to abuse the excessive acceleration and deceleration rates our models are capab
