SCENERY
To all you modellers who haven’t started building terrain on your layouts for one reason or another, start now.
50 layouts and counting and all I’ve ever done is run trains and place a few buildings.
I think I thought that my efforts wouldn’t measure up!!!
Today I was procrasting again and then I decided I’ve nothing to lose and you modellers have encouraged me to start.
I plasted about 4’ of terrain building a waterfall etc., and let me tell you, it looks a dam sight better than plain board.
I’ll be slapping on that plaster for all it’s worth.
God bless and thanks for the encouragement, Alan.
Let the fun begin. I have been so busy with scenery, my trains don’t run. So how bout a pic
So now you have vast plaster plains instead of a plywood desert.[:)] You’ll be amazed how a quick coat of paint will improve the looks of that.
Wait till you paint it up a nice, very light, tan colour and then sprinkle ground foam. It will be an instant forehead slapper…makes all the difference. Then, you sprinkle some “bushes” here and there, drill holes for a few trees and utility poles, and suddenly you have something that you can proudly show friends and neighbours. And, even though they may have seen what you had previously, they’ll exclaim, “Wow, I never knew you were into this!” because it will be so novel and marvelous. [:D]
Alan, I don’t want to take away from your fun with plaster, but if you get a chance to switch up your materials, give Sculptamold a try. It’s very easy to work with and no where near as messy as plaster has the potential to be. It was one of the first materials I worked with and I love it. Of course, I am the constructive equivalent of Messy Marvin so the Sculptamold is a better choice for me. Good luck to you.
Dan
Thanks everyone for your support and ideas.
My layout is 23’ x 14’ and it will have 2 continous lines and a shuting area eventually.
As I am on a pension any money I can save on scenery will be spent on track, controlls, rolling stock, points, buildings and lighting.
So I will be doing my scenery with a lot of sawdust and I already have a large bag of dental plaster. For the foliage of my trees I’ll be using coconut fibre, which I get for nothing from an upholstery repairer.
God bless and may you all have a joyous Christmas, Alan
I sure would appreciate any techniques for making waterfalls just using plaster and gluing rocks onto the plaster.
SHUNTING area that is, der.
Hi Alan If you have no scenery, you are no way near the point of “slapping” on the plaster . You first have to “Dream”,“Plan”, then “Build”. What is your scenery goal, as to “place, era” etc? Is there any background? You should have the background completed, before you start with the plaster. I just completed repainting the sky of my 24’x24’ around the wall layout, (with a roller brush on a long handle. The color of the blue sky was matched (electronically, at the paint store) to the blue color of the top of 200" of SceniKing sectional banner paper background. The paper sections were glued in place with a huge glue stick. One of my rivers is built on an old frontless sliding “pull-out” kitchen drawer, to provide access to the area in the rear. Kalmbach, has several excellent books on scenery construction. Waterfalls, are really not too hard to construct. For deciduous trees, I use furnace filters that are cut in circles and pressed onto half wooden skewers (pressed into holes in preshaped ,stained 2" thick bases of Styrofoam . I sprinkle ground up Woodland Scenic green foam clumps
