Try: http://www.altezeitgruppe.com/scenic_treatment.htm for some ideas for grasses and lineside grenery. All the materials are easily obtained and it is possible to obtain the same results yourself.
Lots of photos.
Tim
Lots of photos.
Tim
Those are some great photos, but I’m not sure that product is available in the USofA.
Well done. Very Realistic, especially the first Pix.
Where is the stuff from? Can it be had here?
All the products are listed in the text, they are mostly from Heki which is widely available in the US but try Scenic Express. The rocks are a urethane casting of a quarry and made by Noch, it was cut down to fit and sprayed with ordinary modeller’s matt white (the casting was not affected) and coloured with inks. The trees in the big picture are WS but I just used the filigree branches and not the awful plastic armatures.
I promise that I will update the webpage with more product codes so that you can order the items but you really should read the text because all the info is in there.
