At age 65, I grew up with slotted and Phillips head screwdrivers & fasteners, and a number of years ago I got indoctrinated in Torx drivers and fasteners.
Now I’ve found a loco has some screws with 6 “edges” (for want of a better word) as compared to a Phillips “4 edges”. Is this called a “star” screw and is the driver called a “star” driver - or what?
The Torx screws I am familiar with have a “sizeable” opening in the center. This center opening is smaller with the 6 “edges” flared out from it - kind of like a star. Perhaps its a different type of Torx, just as there is with Phillips. I’ve got a good selection of minature Torx drivers and they just don’t fit.
What kind of screws are these? Last summer I was building a deck, and I went to the local ‘home center’ store expection to buy those stainless steel deck screws that have a 'square; slot in them. The guy there talking me out of them and said most new construction used a 6 edge slot screw. He expalined that there was mote ‘bite’ for the drill bit(and they cast less, and he got to sell me some new ‘bits’). I drove over 1400 of them into the deck! Of course these were larger screws, but sound similar to what you have.
In looking at the provided website, none of the screw types look exactly like mine. The Torx comes the closest, but the center circular hole is relatively smaller on mine. Perhaps it is a Torx, and I just don’t have the correct size.
Not a big deal, for I may just file a slotted driver so as to fit in two opposing openings.
Ha, sometimes the “easiest” things to do seem to give the most difficulty.
Sounds like could be that, but very doubtful they would use a male torx that small I have standard torx in 4-40
If your bolt looks like the one on the left it’s a torx if it looks like the tool on the right it’s a male torx head screw. I thik you just have a very tiny standard torx screw
I have been a industrial machine mechanic for many years and I have some sets of Torx the smallest being a number 9. There might be smaller but I have not seen them. I have never seen them in model trains.
If this is an older loco, or one that has been worked on, there is a small sized screw with a head opening similar to what you use an allen wrench on. These are commonly called a spline wrench, and at first glance, look a lot like the torx, but there are minor differences. The wrenches are made just like the allens, a bent “key” type wrench.
To only add to the confusion, there were 4 and 6 point splines.
My one time, state of the art, high end digital camera can’t take a detail picture of the screw. It is a replacement screw, and definitely a newer type. If you can picture a regular torx screw, with a lot more spline and a lot less center hole, that is what I have.
Any chance it could be a tamper proof screw? They come in some pretty weird configurations but they’re mostly larger sized for things like appliances and electronics. I don’t know if they come in sizes small enough for models and I doubt they would be used on a model, but, hey, it’s a thought.
