SD70MAC
Question?: What was the purpose of this fan? Exhaust air up for dynamic brakes? Blow air down to cool traction motors?
Cool the electrical panels (how)? All three? None of these and something else?
Thanks.
It is indeed the cooling fan for the DB grid.
EMD placed the DB grid behind the cab on six axle units starting with the SD50. It was moved to the far rear of the unit (behind the radiator) on the SD70ACe and SD70M-2.
Thanks. Where are the fans for the traction motor blowers and for the electrical panel cooling located?
The SD70MAC has an engine driven traction motor/alternator blower on the loco left side behind the bulge to the rear of the DB inlet screen and below the inertial air filter screens. All six motors are cooled by this dual wheel blower, the rear truck air going down the loco left side in the duct on top of the underframe below the walkway. Some air is diverted from the traction motor blower thru paper filters to ventilate the electrical control cabinet, about 600 cfm. The traction motors each get about 2800 cfm. The alternator gets about 8000 cfm which is exhausted into the engine room to pressurize it to keep dirt out and ventilate it.
This is the same basic arrangement introduced on the GP30 and used on all successive models. The SD70 and SD70M were the first units since to incorporate electrically driven traction motor blowers, with separate blowers for each truck. The SD70MAC, however, did not have that arrangement as it was an update of the SD60MAC design, pre-dating the SD70.
Dave
Thanks for a cpomplete explanaition.
Dave: Thanks!! What a great response, my questions are answered!!!
This explains the flatter and wider bulge on the 70/70M compared to the angled blower duct on the 70MAC and previous units.
I’d never known what that change signified.
What did the SD90 use? I know it looks like there’s a standard older rounded blower duct laid flat underneath the raised walkway on the SD90.
The SD80/90MAC had similar electric blowers to the SD70 for the traction motor cooling as well as an electric alternator blower. They also had electric driven water cooled air compressors; EMD wasn’t a fan of the air cooled compressor used by GE.
The H engine, which those locos were designed to use eventually, short-sightedly had no provision on the engine rear (alternator end) to drive a mechanical blower and aux gen. IIRC, they drove the aux gen at the engine front end. Although I did the original locomotive design/equipment layouts for the SD80MAC, I moved on to other projects before they were built so don’t recall all the final details. I do remember that the 20-710 in the SD80’s had a high pressure external oil system unlike all other EMD 2-stroke engines which had a scavenging oil pump with low pressure external plumbing for the oil cooler and filter loop.
Dave
Considering talking about equipment locations on the MACs, I’m linking the maintenance access diagram and equipment location diagram for anyone who could find it useful in the future.
