Ok I picked up two undecorated DC SD80MACs I’m wanting to get DCC put in and also some detailing done.
I’m looking at Loksound decoders for it, I want the “full throttle” function.
I want the ditchlights to flash, front and back headlights directional, marker lights working, numberboards lit, and I’m adding gyralights to the nose of the units so having those fade on and off to simulate the oscillation would be nice.
I’m wanting at least two speakers one facing out each side of the hood and maybe a small one facing upwards.
Is this realistic/acheiveable?
I have a guy to do the install but I’d like to get a shopping list for the parts I need.
From my knowledg, the SD80MACs that I see out at Enola and Harrisburg don’t have gyralights. If they did, NS removed them like they did with the marker lights. I have only seen modern 80MACs with headlights, markerlights and ditchlights.
That’s 6 functions, unless you are putting ditch lights on the back as well. 6 functions is what the Loksound select is. If you need the extra 2, the Select 21MTC and an appropriate motherboard will get you 8 total functions.
Yes, I had painted a car myself, the problem was the light green I want to use is supposedly “satin” instead it came out in a bubbly gloss finish.
It ended up coming out “decent/acceptable” but I really wouldn’t want to do it to another car and it come out horrible.
Then again I might try Tamiya Paints because I was using Rustoleum, I could also see if Krylon has the colors, I couldn’t find them the other day I will try again though.
ANd while I have used Rustoleum paint (and more often, the even cheaper ‘store brand’ at WalMart) for things like painting metal weights flat black, and car axles, etc, as the super cheap paint seems to have a very fine pigment, I have not attempted to paint an entire car body with paints like Rustoleum and Krylon - I don’t trust that it has fine enough pigments not to cover fine detail no matter how lightly you spray it.
Probably still cheaper than the little cans of “model paint” at least Testors - which at one point was at least $7 for that little spray bottle. Which is why I switched to the Walmart stuff for flat black, $1.99 for a BIG can compared to $7 for the tiny can of Testors. Even at twice the price, the big can is more than 3x the paint, so still a deal.
