Seeking prototype info - weights of locos
OK, so here’s what I’m looking for. I want to know approximate weights of prototype locomotives from the late 50’s. More specifically, I am modeling a fictitious branch of the Southern Railway, and will be drawing from their ‘pool’ of motive power from about 1957. So that means F units, RS-3’s, various types of switchers, etc. Also, the branchline splits, and the mining company has a few old steamers they use. I have a couple models of the Russian Decapods, so I need approximate weight on these, along with other smaller steamers a small mining operation in the late 50’s might have.
Now here’s the kicker, and the reason for the question. The premise is they have an ancient bridge which has a strict limit of ~250 tons, regardless of axle loading. Now as this is a mining branch, inbound cars are empties, and outbound loads are open hoppers. So, using Athearn 34’ offset side cars, these represent capacities of about 55 tons. Add the empy/tare weight and it’ll be in the 70-75 ton range. With 3 of these, and that bridge, being the approximate length of three of these cars, will be pretty close to its limit. Now, if a pair of diesels, be it RS-3’s, F units, or some big steamer, an idler car or two will be in order, to keep the weight under control. So if I select something that will move the train, without overloading the bridge (just like in real life), I can mitigate the need for an idler.
As always, thanks in advance.
Brad
Well, I can help with the Russian Decapod weight. IRM has the weight of SLSF 1630 listed at 210000 lbs. That is less than the loaded weight of two of your hopper cars, I would think that it would be fine w/o an idler flatcar on the bridge.
IRM SLSF 1630 specs: http://www.irm.org/cgi-bin/rsearch.cgi?steam=St.+Louis-San+Francisco+Railroad=1630
  • James
A very quick google search turned up this for the RS-3 in 30 seconds:
Locomotive Specifications:
Engine: 244
Trucks: B-B
Truck Type: AAR-B
Fuel (gals.):
Sand (CuFt):
Weight (lbs): 248,100
Horsepower: 1,600
Traction Motors:
Tractive Effort:
Gearing: 74:18
A 15 second google search turned up this on the Decapod:
"Following that, a sm
