She’ll be comin’ round the mountain, or will she?
Has anyone done or seen a helix that runs around the outside of a mountain as it climbs? Is it even possible, with loops getting smaller as you go up?
Just trying to think of a way to prettify a helix and make it interesting.
as it spirals inward, would the change in elevation decrease in order to maintain a reasonable grade?
Yes, but with there are caveats that the video shows.
Interior view of the helix.
Helix by Bear, on Flickr
I have also seen, in a model railroad magazine, I can’t remember which one, where the modeller did a cut away section which depicted the interior of a tunnel. Looked good to me.
A fine looking boat on that flatcar. How long is the mainline on that layout?
There was a guy on this forum I believe that built a Polar Express layout including that mountain scene. There may be a YouTube of it. I think it was N scale, it was spectacular.
I imagine it would have to decrease in elevation, now that you mention it. The calculations on that’ll require aspirin…
If the mountainside helix won’t work, the cutaway tunnel sounds like a good alternative…:thinking:
will those inner tracks near the top be behind the lower track?
If you mean smaller radius, that’s what I was picturing. With a span bridge running from top of helix Mtn to level two.
Gidday Brian, the number of aspirins required depends on several factors…
How much space do you have for a helix?
Where will it be situated in your “train” room?
What is your preferred minimum radius?
What is your preferred grade?
What elevation do you what to achieve?
Double or single tracked?
What scale?
Your construction skills?
Cheers, the Curious Bear. :slightly_smiling_face:
here’s one possibility
  • 2" horizontal separation between tracks
  • maintains 2% effective grade accounting for grade due to curvature of 32/rad (HO)
  • requires ~39" initial radius to rise 16"
thickness = 1.5
#       x        z        y      rad        gr
   38.408    0.080    6.772   39.000      1.18
   36.596    0.160   13.320   38.944      1.18
   33.679    0.240   19.444   38.889      1.18
   29.748    0.320   24.962   38.833      1.18
   24.926    0.399   29.706   38.778      1.17
   19.361    0.478   33.534   38.722      1.17
   13.225    0.558   36.335   38.667      1.17
    6.705    0.636   38.025   38.611      1.17
    0.000    0.715   38.556   38.556      1.17
   -6.685    0.794   37.915   38.500      1.17
  -13.149    0.872   36.126   38.444      1.17
  -19.194    0.950   33.246   38.389      1.17
  -24.640    1.028   29.365   38.333      1.17
  -29.322    1.106   24.604   38.278      1.16
  -33.101    1.183   19.111   38.222      1.16
  -35.865    1.261   13.054   38.167      1.16
  -37.532    1.338    6.618   38.111      1.16
  -38.056    1.415    0.000   38.056      1.16
  -37.423    1.491   -6.599   38.000      1.16
  -35.656    1.568  -12.978   37.944      1.16
  -32.813    1.644  -18.944   37.889      1.16
  -28.982    1.721  -24.319   37.833      1.15
  -24.283    1.797  -28.939   37.778      1.15
  -18.861    1.872  -32.668   37.722      1.15
  -12.883    1.948  -35.395   37.667      1.15
   -6.531    2.023  -37.040   37.611      1.15
   -0.000    2.099  -37.556   37.556      1.15
    6.512    2.174  -36.930   37.500      1.15
   12.807    2.248  -35.186   37.444      1.15
   18.694    2.323  -32.380   37.389      1.14
   23.997    2.397  -28.599   37.333      1.14
   28.556    2.472  -23.962   37.278      1.14
   32.235    2.546  -18.611   37.222      1.14
   34.925    2.620  -12.712   37.167      1.14
   36.547    2.693   -6.444   37.111      1.14
   37.056    2.767   -0.000   37.056      1.14
   36.438    2.840    6.425   37.000      1.14
   34.716    2.913   12.636   36.944      1.13
   31.947    2.986   18.444   36.889      1.13
   28.216    3.059   23.676   36.833      1.13
   23.640    3.131   28.173   36.778      1.13
   18.361    3.203   31.802   36.722      1.13
   12.541    3.275   34.455   36.667      1.13
    6.357    3.347   36.055   36.611      1.13
    0.000    3.419   36.556   36.556      1.12
   -6.338    3.491   35.945   36.500      1.12
  -12.465    3.562   34.247   36.444      1.12
  -18.194    3.633   31.514   36.389      1.12
  -23.355    3.704   27.833   36.333      1.12
  -27.790    3.775   23.319   36.278      1.12
  -31.369    3.845   18.111   36.222      1.12
  -33.986    3.916   12.370   36.167      1.12
  -35.563    3.986    6.271   36.111      1.11
  -36.056    4.056    0.000   36.056      1.11
  -35.453    4.126   -6.251   36.000      1.11
  -33.777    4.195  -12.294   35.944      1.11
  -31.081    4.265  -17.944   35.889      1.11
  -27.450    4.334  -23.033   35.833      1.11
  -22.998    4.403  -27.407   35.778      1.11
  -17.861    4.472  -30.936   35.722      1.10
  -12.199    4.540  -33.516   35.667      1.10
   -6.184    4.609  -35.070   35.611      1.10
   -0.000    4.677  -35.556   35.556      1.10
    6.165    4.745  -34.961   35.500      1.10
   12.123    4.813  -33.307   35.444      1.10
   17.694    4.880  -30.648   35.389      1.10
   22.712    4.948  -27.067   35.333      1.09
   27.024    5.015  -22.676   35.278      1.09
   30.503    5.082  -17.611   35.222      1.09
   33.046    5.149  -12.028   35.167      1.09
   34.578    5.216   -6.097   35.111      1.09
   35.056    5.282   -0.000   35.056      1.09
   34.468    5.349    6.078   35.000      1.09
   32.837    5.415   11.952   34.944      1.08
   30.215    5.481   17.444   34.889      1.08
   26.684    5.546   22.390   34.833      1.08
   22.355    5.612   26.641   34.778      1.08
   17.361    5.677   30.070   34.722      1.08
   11.857    5.742   32.576   34.667      1.08
    6.010    5.807   34.085   34.611      1.08
    0.000    5.872   34.556   34.556      1.07
   -5.991    5.936   33.976   34.500      1.07
  -11.781    6.001   32.367   34.444      1.07
  -17.194    6.065   29.782   34.389      1.07
  -22.069    6.129   26.301   34.333      1.07
  -26.258    6.193   22.033   34.278      1.07
  -29.637    6.256   17.111   34.222      1.06
  -32.106    6.320   11.686   34.167      1.06
  -33.593    6.383    5.923   34.111      1.06
  -34.056    6.446    0.000   34.056      1.06
  -33.483    6.509   -5.904   34.000      1.06
  -31.897    6.571  -11.610   33.944      1.06
  -29.349    6.634  -16.944   33.889      1.06
  -25.918    6.696  -21.748   33.833      1.05
  -21.712    6.758  -25.875   33.778      1.05
  -16.861    6.820  -29.204   33.722      1.05
  -11.515    6.881  -31.636   33.667      1.05
   -5.837    6.943  -33.100   33.611      1.05
   -0.000    7.004  -33.556   33.556      1.05
    5.817    7.065  -32.991   33.500      1.04
   11.439    7.126  -31.427   33.444      1.04
   16.694    7.187  -28.916   33.389      1.04
   21.426    7.247  -25.535   33.333      1.04
   25.492    7.308  -21.391   33.278      1.04
   28.771    7.368  -16.611   33.222      1.04
   31.166    7.428  -11.344   33.167      1.04
   32.608    7.487   -5.750   33.111      1.03
   33.056    7.547   -0.000   33.056      1.03
   32.499    7.606    5.730   33.000      1.03
   30.958    7.665   11.268   32.944      1.03
   28.483    7.724   16.444   32.889      1.03
   25.152    7.783   21.105   32.833      1.03
   21.069    7.841   25.109   32.778      1.02
   16.361    7.900   28.338   32.722      1.02
   11.173    7.958   30.697   32.667      1.02
    5.663    8.016   32.116   32.611      1.02
    0.000    8.074   32.556   32.556      1.02
   -5.644    8.131   32.006   32.500      1.02
  -11.097    8.189   30.488   32.444      1.01
  -16.194    8.246   28.050   32.389      1.01
  -20.783    8.303   24.769   32.333      1.01
  -24.726    8.360   20.748   32.278      1.01
  -27.905    8.416   16.111   32.222      1.01
  -30.227    8.473   11.002   32.167      1.01
  -31.623    8.529    5.576   32.111      1.00
  -32.056    8.585    0.000   32.056      1.00
  -31.514    8.641   -5.557   32.000      1.00
  -30.018    8.696  -10.926   31.944      1.00
  -27.617    8.752  -15.944   31.889      1.00
  -24.386    8.807  -20.462   31.833      0.99
  -20.426    8.862  -24.343   31.778      0.99
  -15.861    8.917  -27.472   31.722      0.99
  -10.831    8.972  -29.757   31.667      0.99
   -5.489    9.026  -31.131   31.611      0.99
   -0.000    9.080  -31.556   31.556      0.99
    5.470    9.134  -31.021   31.500      0.98
   10.755    9.188  -29.548   31.444      0.98
   15.694    9.242  -27.184   31.389      0.98
   20.141    9.296  -24.003   31.333      0.98
   23.960    9.349  -20.105   31.278      0.98
   27.039    9.402  -15.611   31.222      0.98
   29.287    9.455  -10.660   31.167      0.97
   30.638    9.508   -5.402   31.111      0.97
   31.056    9.560   -0.000   31.056      0.97
   30.529    9.612    5.383   31.000      0.97
   29.078    9.665   10.584   30.944      0.97
   26.751    9.717   15.444   30.889      0.96
   23.620    9.768   19.819   30.833      0.96
   19.784    9.820   23.577   30.778      0.96
   15.361    9.871   26.606   30.722      0.96
   10.489    9.922   28.817   30.667      0.96
    5.316    9.973   30.146   30.611      0.95
    0.000   10.024   30.556   30.556      0.95
   -5.296   10.075   30.037   30.500      0.95
  -10.413   10.125   28.608   30.444      0.95
  -15.194   10.175   26.318   30.389      0.95
  -19.498   10.225   23.237   30.333      0.95
  -23.194   10.275   19.462   30.278      0.94
  -26.173   10.325   15.111   30.222      0.94
  -28.347   10.374   10.318   30.167      0.94
  -29.654   10.424    5.229   30.111      0.94
  -30.056   10.473    0.000   30.056      0.94
  -29.544   10.522   -5.209   30.000      0.93
  -28.139   10.570  -10.242   29.944      0.93
  -25.885   10.619  -14.944   29.889      0.93
  -22.854   10.667  -19.176   29.833      0.93
  -19.141   10.715  -22.811   29.778      0.93
  -14.861   10.763  -25.740   29.722      0.92
  -10.147   10.811  -27.878   29.667      0.92
   -5.142   10.858  -29.161   29.611      0.92
   -0.000   10.905  -29.556   29.556      0.92
    5.123   10.953  -29.052   29.500      0.92
   10.071   10.999  -27.669   29.444      0.91
   14.694   11.046  -25.452   29.389      0.91
   18.855   11.093  -22.471   29.333      0.91
   22.428   11.139  -18.819   29.278      0.91
   25.307   11.185  -14.611   29.222      0.90
   27.408   11.231   -9.976   29.167      0.90
   28.669   11.277   -5.055   29.111      0.90
   29.056   11.322   -0.000   29.056      0.90
   28.559   11.368    5.036   29.000      0.90
   27.199   11.413    9.900   28.944      0.89
   25.019   11.458   14.444   28.889      0.89
   22.088   11.503   18.534   28.833      0.89
   18.498   11.547   22.045   28.778      0.89
   14.361   11.592   24.874   28.722      0.89
    9.805   11.636   26.938   28.667      0.88
    4.968   11.680   28.176   28.611      0.88
    0.000   11.724   28.556   28.556      0.88
   -4.949   11.767   28.067   28.500      0.88
   -9.729   11.811   26.729   28.444      0.87
  -14.194   11.854   24.585   28.389      0.87
  -18.212   11.897   21.705   28.333      0.87
  -21.662   11.940   18.177   28.278      0.87
  -24.441   11.983   14.111   28.222      0.87
  -26.468   12.025    9.634   28.167      0.86
  -27.684   12.067    4.881   28.111      0.86
  -28.056   12.109   -0.000   28.056      0.86
  -27.575   12.151   -4.862   28.000      0.86
  -26.259   12.193   -9.558   27.944      0.85
  -24.152   12.234  -13.944   27.889      0.85
  -21.322   12.276  -17.891   27.833      0.85
  -17.855   12.317  -21.279   27.778      0.85
  -13.861   12.358  -24.008   27.722      0.85
   -9.463   12.398  -25.998   27.667      0.84
   -4.795   12.439  -27.192   27.611      0.84
    0.000   12.479  -27.556   27.556      0.84
    4.775   12.519  -27.082   27.500      0.84
    9.387   12.559  -25.789   27.444      0.83
   13.694   12.599  -23.719   27.389      0.83
   17.570   12.639  -20.939   27.333      0.83
   20.896   12.678  -17.534   27.278      0.83
   23.575   12.717  -13.611   27.222      0.82
   25.528   12.756   -9.292   27.167      0.82
   26.699   12.795   -4.708   27.111      0.82
   27.056   12.834    0.000   27.056      0.82
   26.590   12.872    4.689   27.000      0.81
   25.319   12.910    9.216   26.944      0.81
   23.286   12.948   13.444   26.889      0.81
   20.556   12.986   17.248   26.833      0.81
   17.212   13.024   20.513   26.778      0.80
   13.361   13.061   23.142   26.722      0.80
    9.121   13.098   25.058   26.667      0.80
    4.621   13.135   26.207   26.611      0.80
   -0.000   13.172   26.556   26.556      0.79
   -4.602   13.209   26.097   26.500      0.79
   -9.045   13.245   24.850   26.444      0.79
  -13.194   13.281   22.853   26.389      0.79
  -16.927   13.318   20.173   26.333      0.78
  -20.130   13.353   16.891   26.278      0.78
  -22.709   13.389   13.111   26.222      0.78
  -24.589   13.425    8.950   26.167      0.78
  -25.714   13.460    4.534   26.111      0.77
  -26.056   13.495   -0.000   26.056      0.77
  -25.605   13.530   -4.515   26.000      0.77
  -24.380   13.565   -8.874   25.944      0.77
  -22.420   13.599  -12.944   25.889      0.76
  -19.789   13.633  -16.605   25.833      0.76
  -16.570   13.668  -19.747   25.778      0.76
  -12.861   13.701  -22.276   25.722      0.76
   -8.779   13.735  -24.119   25.667      0.75
   -4.447   13.769  -25.222   25.611      0.75
    0.000   13.802  -25.556   25.556      0.75
    4.428   13.835  -25.113   25.500      0.75
    8.703   13.868  -23.910   25.444      0.74
   12.694   13.901  -21.987   25.389      0.74
   16.284   13.934  -19.406   25.333      0.74
   19.364   13.966  -16.248   25.278      0.73
   21.843   13.998  -12.611   25.222      0.73
   23.649   14.030   -8.608   25.167      0.73
   24.730   14.062   -4.360   25.111      0.73
   25.056   14.094    0.000   25.056      0.72
   24.620   14.125    4.341   25.000      0.72
   23.440   14.156    8.532   24.944      0.72
   21.554   14.187   12.444   24.889      0.71
   19.023   14.218   15.963   24.833      0.71
   15.927   14.249   18.981   24.778      0.71
   12.361   14.279   21.410   24.722      0.71
    8.436   14.309   23.179   24.667      0.70
    4.274   14.339   24.237   24.611      0.70
   -0.000   14.369   24.556   24.556      0.70
   -4.254   14.399   24.128   24.500      0.69
   -8.360   14.428   22.970   24.444      0.69
  -12.194   14.458   21.121   24.389      0.69
  -15.641   14.487   18.640   24.333      0.68
  -18.598   14.516   15.605   24.278      0.68
  -20.977   14.544   12.111   24.222      0.68
  -22.709   14.573    8.265   24.167      0.68
  -23.745   14.601    4.187   24.111      0.67
  -24.056   14.629   -0.000   24.056      0.67
  -23.635   14.657   -4.168   24.000      0.67
  -22.500   14.685   -8.189   23.944      0.66
  -20.688   14.712  -11.944   23.889      0.66
  -18.257   14.740  -15.320   23.833      0.66
  -15.284   14.767  -18.215   23.778      0.65
  -11.861   14.794  -20.544   23.722      0.65
   -8.094   14.821  -22.239   23.667      0.65
   -4.100   14.847  -23.252   23.611      0.64
    0.000   14.874  -23.556   23.556      0.64
    4.081   14.900  -23.143   23.500      0.64
    8.018   14.926  -22.031   23.444      0.64
   11.694   14.952  -20.255   23.389      0.63
   14.998   14.977  -17.874   23.333      0.63
   17.832   15.003  -14.963   23.278      0.63
   20.111   15.028  -11.611   23.222      0.62
   21.770   15.053   -7.923   23.167      0.62
   22.760   15.078   -4.013   23.111      0.62
   23.056   15.102    0.000   23.056      0.61
   22.651   15.127    3.994   23.000      0.61
   21.561   15.151    7.847   22.944      0.61
   19.822   15.175   11.444   22.889      0.60
   17.491   15.199   14.677   22.833      0.60
   14.641   15.223   17.449   22.778      0.60
   11.361   15.246   19.678   22.722      0.59
    7.752   15.269   21.300   22.667      0.59
    3.926   15.292   22.268   22.611      0.58
   -0.000   15.315   22.556   22.556      0.58
   -3.907   15.338   22.158   22.500      0.58
   -7.676   15.360   21.091   22.444      0.57
  -11.194   15.383   19.389   22.389      0.57
  -14.356   15.405   17.108   22.333      0.57
  -17.066   15.427   14.320   22.278      0.56
  -19.245   15.448   11.111   22.222      0.56
  -20.830   15.470    7.581   22.167      0.56
  -21.775   15.491    3.840   22.111      0.55
  -22.056   15.512   -0.000   22.056      0.55
  -21.666   15.533   -3.820   22.000      0.55
  -20.621   15.554   -7.505   21.944      0.54
  -18.956   15.575  -10.944   21.889      0.54
  -16.725   15.595  -14.034   21.833      0.53
  -13.998   15.615  -16.683   21.778      0.53
  -10.861   15.635  -18.812   21.722      0.53
   -7.410   15.655  -20.360   21.667      0.52
   -3.753   15.675  -21.283   21.611      0.52
    0.000   15.694  -21.556   21.556      0.52
    3.733   15.713  -21.173   21.500      0.51
    7.334   15.732  -20.151   21.444      0.51
   10.694   15.751  -18.523   21.389      0.50
   13.713   15.770  -16.342   21.333      0.50
   16.300   15.788  -13.677   21.278      0.50
   18.379   15.806  -10.611   21.222      0.49
   19.890   15.824   -7.239   21.167      0.49
   20.790   15.842   -3.666   21.111      0.48
   21.056   15.860    0.000   21.056      0.48
   20.681   15.877    3.647   21.000      0.48
   19.681   15.895    7.163   20.944      0.47
   18.090   15.912   10.444   20.889      0.47
   15.959   15.928   13.391   20.833      0.46
   13.356   15.945   15.917   20.778      0.46
   10.361   15.962   17.946   20.722      0.46
    7.068   15.978   19.420   20.667      0.45
    3.579   15.994   20.298   20.611      0.45
   -0.000   16.010   20.556   20.556      0.44
i don’t think that will work because there won’t be enough clearance between it and the next lower helix track
choose your grade
#   rad tot-gr     ht     circ     gr eff-gr  N-scale
     17   3.64   2.79    106.8   2.61   1.03
     18   3.43   2.79    113.1   2.46   0.97
     19   3.25   2.79    119.4   2.33   0.92
     20   3.09   2.79    125.7   2.22   0.88
     21   2.94   2.79    131.9   2.11   0.83
     22   2.81   2.79    138.2   2.01   0.80
     23   2.69   2.79    144.5   1.93   0.76
     24   2.58   2.79    150.8   1.85   0.73
     25   2.47   2.79    157.1   1.77   0.70
     26   2.38   2.79    163.4   1.70   0.67
     27   2.29   2.79    169.6   1.64   0.65
     28   2.21   2.79    175.9   1.58   0.62
     29   2.13   2.79    182.2   1.53   0.60
     30   2.06   2.79    188.5   1.48   0.58
#   rad tot-gr     ht     circ     gr eff-gr  HO-scale
     24   3.80   3.71    150.8   2.46   1.33
     25   3.65   3.71    157.1   2.37   1.28
     26   3.50   3.71    163.4   2.27   1.23
     27   3.38   3.71    169.6   2.19   1.19
     28   3.25   3.71    175.9   2.11   1.14
     29   3.14   3.71    182.2   2.04   1.10
     30   3.04   3.71    188.5   1.97   1.07
     31   2.94   3.71    194.8   1.91   1.03
     32   2.85   3.71    201.1   1.85   1.00
     33   2.76   3.71    207.3   1.79   0.97
     34   2.68   3.71    213.6   1.74   0.94
     35   2.60   3.71    219.9   1.69   0.91
     36   2.53   3.71    226.2   1.64   0.89
     37   2.46   3.71    232.5   1.60   0.86
     38   2.40   3.71    238.8   1.56   0.84
     39   2.34   3.71    245.0   1.52   0.82
     40   2.28   3.71    251.3   1.48   0.80
     41   2.22   3.71    257.6   1.44   0.78
     42   2.17   3.71    263.9   1.41   0.76
     43   2.12   3.71    270.2   1.38   0.74
     44   2.07   3.71    276.5   1.34   0.73
     45   2.03   3.71    282.7   1.31   0.71
     46   1.98   3.71    289.0   1.29   0.70
I’m working in N scale, btw.
still applies
I was thinking 5-6’ square
It would be in the empty garage, at on end of a wall wraparound (possibly two helix’, one at each end)
I’m doing N scale. My preferred radius is the one that doesn’t cause derailments.:wink: Though seriously, whatever I can get away with and still run long cars or even a Big Boy. Not so much worried about the aesthetics of it as long as they run.
2% max.
Undefined as yet (still in the planning stages). I still can’t decide on distance between decks 1 and 2. I’m guessing between 18-24”?
I really want double track, but doubt it’s feasible with decreasing radii including room for cliffs.
What scale?
N scale.
Moderate. I can almost always accomplish what I set out to do. Eventually.
Understood, just wanted to make sure you’re calculating using the correct scale.
the radius dictates the grade.
The proportions will be the same; there may even be a bit less clearance in N because the physical distance down from the railheads to the bottom of the bridge structure may be greater in proportion.
It should be possible to adjust the helix turns so that the rise can be lessened at the last turn or two, with proper vertical-curve transitions, to clear the lowest effective interference with the bridge. Gregc’s program should facilitate the analysis.
lessened? don’t you mean increased?
those last (top) turns are when the radius is the smallest and when it would require a significant grade to achieve the clearance above the previous turn, if not more that one turn
i think you’re better off with a conventional, constant radius helix, which i believe might be 25" for an effective grade of 2.47 (see above)
What I mean is decreasing the track gradient given a fixed overall helix height, probably in more than one of the turns below the ‘bridge’ – it would then be slightly increased again for the last turn of the helix leading onto the bridge.
You’re correct in thinking there is a minimum vertical space available because the ‘compensation’ for curve and grade is determined by the tightening radius as you go up the ‘wedding cake’. What I’d propose is offsetting the last turn at the back of the top turn into an oval, even going out and back through a wall, to get the lower ruling grade on that section.
