I am trying to find ways to efficiently illuminate a long shelf layout.
The layout itself is generally 1’ deep, and currently runs along 12’ of an 18’x8’ room–eventually it will run around three sides of the room.
The shelf itself is 48" high, and there is a shelf above it at 66" high. This shelf will have a 3" fascia board of 1/8" hardboard. The moveable layout modules are about 2" thick, so the distance from layout surface to top of shelf is about 16". This may seem narrow, but the ceiling in my garage is only 7’ high and I need a certain amount of storage space above the layout.
Currently, my lighting system consists of a rope light that runs the entire length of the layout, clipped to the underside of the shelf. This is suitable for a soft evening glow sort of illumination, but I want to simulate a bright summer day.
Towards this end, I have purchased a set of five 20-watt halogen lamps, intended for surface or recessed use in shelving systems or entertainment centers. I plugged four of them in at 3’ intervals along my 12-foot section.
They do provide plenty of light, but since the illumination is kind of directional, it creates four separate parabolas of brightness on my backdrop, with big pits of relative darkness in between.
Question #1:
If I remove the little plastic/glass protective covers from the halogen lamps, the illumination becomes much more broad in coverage–but am I risking fire or other hazards by leaving these covers off the lamps?
Question #2:
I am considering adding a row of low-profile fluorescent fixtures under the upper shelf to provide additional lighting and fill those dark areas. I take my cue for this from Tony Koester’s “Multi-deck layout lighting” article in the June 2004 MR, but am looking for a brighter look–rather than a cool, overcast sort of day, I am hoping to represent a 100+ degree cloudless day in California’s central valley, so the use of fluorescents alon
