shell removal for bachmann sd-40
How do I go about removing this shell? I removed the gas tank cover and removed the 2 screws. I looked at the couplers but they do not attach to the frame. I have pried and pulled and swore and still can’t get the damn thing off. Any suggestions?
You did everything needed. Must have something inside jamed against the shell. Try to wiggle it up in the back first.
Bob
Here is a diagram of the SD40-2 DCC equipped from the Bachmann site that might help. Expand the diagram for a better view. Save the diagram to your PC. Many times there are tabs the grab onto the shell.
http://www.bachmanntrains.com/home-usa/dwg/dwgs/H609X_IS001.PDF
I have the paperwork with the engine and have scanned every last line to figure out what is holding it down. I have tried prying with screwdrivers and even run a panel scriber under the frame as best I could. It almost feels like it is glued down, taped down, or screwed down. I put a lot of force on it with the screwdriver but still nothing. If I pry too much I am afraid I will break it.
