Hello everyone! I am in the process of replacing all of the altlas remote switches with Caboose Industries 202S ground throws on my layout. It looks like they need to be shimmed. What thickness do u recommend? I am not using any roadbed, track is tacked down to plywood base. Thanks!
If the track is nailed directly onto the plywood surface of your layout, then you shouldn’t need a shim under the ground throw. Just nail the ground throw directly to the plywood. That’s exactly what I have done in my coach yard where the track is nailed directly onto the plywood surface. Do yourself a favor and use a pin vice to drill pilot holes so that it will be a lot easier to install the ground throws where you want them without bending any nails.
Thanks! Already drilled them out with the recommended #54 bit.
For a more prototypical look you can install some headblock ties and mount your ground throws to them.
Joe
Rich,
The only thing I would add to richotrain’s response is that I find the pins on the Caboose Industries ground throws are a bit long, protruding below the turnout throw bar. I nip just a bit from them so they won’t rub on the surface underneath (plywood, in your case).
Good luck!
