Hi all.
I am new to the forum and thought I would pose a question. I am in the process of finishing my basement and adding space for a layout. It will be HO scale, although I may make the change to N, and will be located in the left hand room of the image below
I am planning on a shelf type layout as I need to keep the interior of the space open for other uses. The room size is going to be 16’ x 13’ with an 8’ x 3’alcove. I will be doing a double deck layout since I want to increase my mainline run and am not averse to double deck layouts. See the below image for my proposed benchwork layout.
A helix will be located on the upper right corner of the layout. I had planned on making the max width of the benchwork 24" in the proposed yard area (top of image and 15" everywhere else). Am I limiting myself too much using a 15" wide shelf? I do not want to hinder views of the lower deck by going too wide on the top deck. Any thoughts are appreciated.
John
Fort Mill, SC
