SHORT CIRCUIT PROBLEM
I am at my wit’s end with a short circuit problem on my layout. Any help will be appreciated. I have a fairly large layout that I am wiring for DCC. My bus wire is 14 gauge. 20 gauge feeder wires are soldered to the rails every 3 feet or so, and connected to the bus with “suitcase connectors”. Everything is color-coded. The wiring was going along smoothly, until I hit one particular section of track…short! The loco stops the minute it hits there. The track piece was actually hot to the touch. I replaced the track section, but the minute I connect the rails, short! I can see the inside rails sparking when they touch. I’ve double-checked the wiring, and it all looks good. Any ideas as to what else could be causing the short circuits? I’ve disconnected all the wires on the other side of the layout from the short. Thanks!
It would be helpful if we had a track diagram or photo(s). I am assuming the track is electrically isolated at the joint in question, which leads me to think one of two possibilities. Either you have a reversed wire/switch somewhere, or you might have a reversing section or loop.
Brad
I agree with Brad.
Just was through this. Check an insulator that has gone bad and see if one of your drops is the wrong color, I found both!!! Best way I have found to check for shorts while you are under the table is to put a couple of alligator leads to the track and run anything they will power (motor or light, etc), on mine I run a train at slow speed and if I connect a wire wrong, it stops instantly).
Is this a new layout that you are wiring or an existing layout that you are converting from DC to DCC?
The symptoms that you describe very definitely suggest a reverse polarity problem, either caused by a reverse loop or wires crossed and out of phase.
Thanks for the help. This is a new layout that I am wiring, and the section in question is not part of a reversing loop. It shorts out as soon as I connect the inside rail to the bus, or to another piece of track. The outside rail connects just fine. I have kept a loco on the track powered up as I went attaching my feeder wires, with no problems until I hit this one spot. Some other posters have mentioned insulators??? What are they referring to?
Without a track plan, we are left to speculate what your layout looks like and how you are approaching the wiring process.
It sounds as though you have completed the track work and are now wiring it to the bus. If that is the case, and if you are certain that there is no reverse loop or reversing section, then the short is occuring because of mismatched wires.
So far, the feeder wires that you have connected from the rails to the bus have provided electrical current and you are able to run a loco on the powered track. Now you install a set of feeders on the next section of track and a short occurs. That tells me that you have reversed the feeder wires. What happens if you reverse those two feeder wires?
I’ll have to agree with Rich on this one. If the feeders were crossed, the moment the power is on, it will short out… A diagram would certainly be helpful…
Cheers,
Frank
What kind of turnouts are you using? You may have a problem with certain power-routing turnouts if they are not isolated past the frog.
That raises another good question.
Is the OP wiring sequentially, section by section, as he moves around the layout? Or, are different parts of the layout already wired as the OP adds feeder wires in between previously wired sections of the layout?
In his initial post, he mentioned he “disconnected all the wires on the other side of the layout from the short”.
All the turnouts on the layout are made by Atlas. I don’t believe that I need to do anything special with them, but I’m not sure. My feeder wires are red (outside rail) and black (inside rail). Red wire to the outside rail, no problem. Either wire touched to the inside rail causes a short. Black wire to outside rail…short. I am going to go out there today and look at everything again. I’ll also try and figure out how to put a diagram of the layout up here. I know that would be more of a help than my attempts at explaining what it looks like. Thanks for the thoughts.
Atlas turnouts are not power routing.
You mentioned that you replaced the section of track where the short occurred and the same thing happened all over again.
Just out of curiosity, what section of track caused the short? Turnout? Flex track?
Are you simply wiring as you move down the layout or are you wiring different sections on the layout in no particular order?
One last thing, Rich. I do have other parts of the layout wired, without running into any problems. The section that I am having trouble with splits off of the main line and reconnects with it further down the line. I was able to wire approximately one half of it before I ran into this problem. I do have a few feeder wires soldered past the point where it reconnects, but I don’t understand how I was able to solder 4-5 sets of feeders on this particular section without a problem, before I hit this spot. Like I said, I’ll go out there today and recheck everything, and hopefully I’ll still have these last few remaining hairs on my head when I come in! Thanks to all for the thoughts so far.
Do you have a track plan that can be emailed so that we can post it?
I think that we are right back to our original suspicions, either a reversing section that is not obvious to you or feeder wires inadvertently crossed over to the wrong rails.
Another thing that I will mention is that even on very large layouts, where the common recommendation is to drop tons of feeder wires and even solder the connections, it has been my experience that just a few sets of feeder wires will carry power throughout large parts of the layout. The electrical connectivity is usually interrupted only by turnouts and other such specialty track pieces like wyes and slips.
So, when you suddenly encounter a short, it is the result of reverse polarity for whatever the reason.
I had an intermittent short that was driving me crazy. I eventually traced the problem to an Atlas 30-degree crossing. It was shorted internally, and would short the layout when an engine passed over it a certain way.
It’s not a likely scenario, but it’s a possibility.
I think that, at this point, anything is a possibility.
That’s why a track plan would be helpful as well as knowing which track the OP is connecting the feeder wires to that is causing a short - - - a turnout, a specialty track such as a wye or slip, or simply a section of flex track.
I was going to ask if a loco would run on the section before the rails were connected, but then I saw the post where the OP said it also shorts when the feeder is connected not the rails. That is the thing that confuses me. Usually the feeders won’t short unless the rails are already connected.
Also the later note that says this is not the first feeder in the section but about the 5th, that really makes me think something obvious is being assumed, overlooked, or at least not being stated in the messages.
My guess is that there was/is an unknown/forgotten insulated rail joiner or a gap that has been crossed at that particular point in the layout.
An interesting question would be what happens if you disconnect the rail joiners at the opposite end of the track that is shorting after you place feeders on the other end of that track.
I suspect the answer is that there is no longer a short.
