Please forgive me if this has been talked about before .
I recently installed a new tsunami 2 sound decoder in an Atlas gp38
As soon as I cranked up the power cab it read “short circuit detected. I tried another locomotive and it worked fine so I’m thinking the track is fine. Then I put the decoder in another loco and got nothing.
Im thinking I didn’t put electrical tape between the decoder and the motor. Hopefully Soundtrax will send another decoder without many problems. Anyone have any thoughts on this?
if you have a copy of the receipt where you bought it and its been less than a year Soundtraxx will replace it for cost of shipping it to them. make sure to get a RMA number from them before sending it in.
Thanks to everyone. I called Soundtraxx today. They sent a complaint form. If less than 90 days old then they will replace no problems. Very easy to work with.
I just got a Athearn Genesis UP 1943 from my local hobby shop for $250 when i run it with my NCE Powercab It says short circut detected when i tried programing it and it was making a noice when i put it on the track any help?
[#welcome] to the forum, your posts are delayed in moderation for the first few.
Since you just got it, take it back or see if Athearn will fix it under warranty. It could be a lose wire, a defective decoder but once you start monkeying with it, no one will cover the warranty.
Just for clarification: If your PowerCab detects a short it will cycle power off & on until the short is cleared - e.g. removing the locomotive from the track. Is that what is happening?
Well i dont know if the one i have is dcc because it runs fine with my dc oval track but if i put it on my other track with my dcc it it makes a noise so it could be both.
Nope. DCC ready maybe but your description is of a DC locomotive with no decoder installed. I’ve had DCC decoder equipped locomotives refuse to run on DC but a locomotive that runs on DC but refuses to run on DCC has no decoder.
If you still have the box, does it mention on the end panel anything about DCC/Sound Equiped, or say Tsunami 2?
If not, it simply does not have a decoder installed.
If it does say that, sounds like the decoder was not put in properly at the factory, and I would return to either Athearn or place of purchase under warranty.
