Short grades and flyovers question
I live in Kansas City and BNSF / UP and others have built two massive fly-overs and bypasses. I have been over one of the flyovers and its approach is short, but very steep. It looks almost like a highway on ramp. I am not sure of the angle, but seems steep for a railroad. My question is if the length is short does incline rate not really matter?
I ask this because I saw a BNSF transcon stack train stopped on the approach awaiting a signal. He had 4 C9-44Ws and when he got the green it was almost impossible to get going, the engines were definitly in run 8 and the ground was almost shaking underneath. Is this bad design to put a signal on the approach or is it just an annoyance to the engineer?
Thanks,
Chris
Chris,
Interesting post. I know this happens on more than one occassion in Chicago as well. There is an interesting article in Trains, I think, concerning RS-3s and how they were great with handling that kind of pull.
It would be interesting to know the grades on some of those flyovers. Wish I could be of more help.
Gabe
…A short steep flyover being in position where a train must stop for a signal sounds out of place to me, just a fan but I understand what must happen to start something like that under the loaded circumstance…Perhaps it fools the eye in how steep it really is and then, perhaps someone created a monster.
I went to the newest flyover in KC last night, it has a road that parallels half of it, in 1 1/3 miles the track raises from street level to high enough to let 2 double stack trains pass underneath, what would the height of the flyover be then?
…Using say…05% grade {for the 1.3 miles in length for the flyover approach…that would produce 30 plus ft. of clearance for double stacks to run under…and I imagaine less than 25 ft. would be required for clearance…
Well if you did some math you could come to a pretty good idea of the grade
Estimate the height of the flyover
Estimate the amount of feet from the beginning of the flyover to the summit & you would then be able to determine the grade % [8D]
[quote]
Originally posted by ChrisBARailfan
Using the measurements I think it comes to a 1% grade, not that much all in all. Thanks for the posts and information.
Chris
6868 ft. in length of approach (1.3 miles)
70 ft. height at apex (35 ft. for each track underneath the flyover)
