Short in a postwar steam engine?
I purchased a 2026 steam engine, which I’ve clean and oiled. When I place it on the track it causes a short. How do I trouble shoot the short? Anything I should be looking for?
Take the shell off and look for cracked or missing insulation on the wires.
Pay close attention to the wire coming from the pick-up roller.
I had a similar problem with mine. In the back of the engine Under the cover of course, where the direction unit is, there is a round cylinder type thing that allows the engine to change directions (it may be red or white). There are two plastic tabs that allow it to turn in place. The tabs may have broken as mine did. This stops the thing from turning, so you cant change directions and if it is stuck in the middle position, you short out.The part cost $1.00 and if you have the patience you could probably do it yourself. I posted a while back on the topic. going to see if I can find it good luck.
Angelo
http://www.trains.com/community/forum/topic.asp?TOPIC_ID=15502
This is the link to my original post.
If you find that it is the e-unit:
The part is called a drum, has to go back in the same direction as the old one did.
Part #259e-1
Becareful of the delicate part if you decide to do it on your own.
Hope this helps.
Angelo
