short line on a mountain side ?
Hello I am planning to build a mountain with a tunnel. And I would like to run a short line to a small mine. And I am not sure where to start. The mountain/tunnel will be a curve and 7-8 feet from one end to the other and go about 2 feet up. I am thinking of a shay and 2-4 ore cars ? to work the line to make a 8 car train two times a week.
So how should I build the line in the side. I was thinking of using foam for the mountain. should I carve the line in the side? or build the line on a wood frame and foam around it? I am not sure what grade I should use? I would like to have two switch backs. But not sure how to go from one grade to the other. Thanks and have a nice day Frank
Building the support for the track first is suggested. Unlike real mountains, our mountains of foam or plaster might not give enough support for the track (although we usually don’t have to worry about landslides, either).
Plan this out on paper first. The grade to use is up to you, and with a plan for a shay and about four cars at a time it can be fairly steep. Still, grades over about 4% or 5% create operating difficulties even in smaller scales, such as the transition area between level track and that on the grade. One can’t go immediately to a steep grade or risk derailments (it’s like a transition curve only vertical). That track doesn’t have to go to the top of the mountain: The ore seam is not likely at the top, and trying to gain 2’ vertical with a 16’ run (back and forth on a 8’ switchback) would still yield at least a 12.5% grade!
Also, consider in your planning whether or not you will need a run-around track at the top to be able to service that mine. Generally (there were exceptions), railroads with steep grades would try to keep the shay (1) pointed uphill to help keep water over the crown sheet to reduce the risk of a boiler explosion and (2) on the downhill side of the train to reduce the risk of run-aways.
Plan it out. Build the supports and base for your track before filling in the whole mountain with foam or scenery.
Bill
And remember with switchbacks, the grade goes from turnout to turnout (where the next “leg” starts elevating), but you still need enough space past the turnout to hold the entire train.
So if you run 24" trains (about an engine and 3-4 cars in HO), you’ll need at least 24" on the far sides of the turnouts, leaving whatever space inside that to rise in elevation. To rise 2" over 48" (4.2% grade), plus switchback leads, plus slight transition grade (from flat to rise), means at least 8’ of space.
Switchbacks do take up a lot of space (lengthwise) but can be fun or tedious to operate depending on your model railroading interests.
Like Bill said, plan it out first, then you can figure out your benchwork.
Hope this helps.
Looking at a couple of prototype samples here:
  1. The Grande’s Monarch branch (Colorado) serviced a single quarry. When they dieselized, they relaid that one isolated narrow gauge branch to standard, short switchback and all. The switchback gained about twenty feet between switches, or about forty total feet from the switchstand of the lower tail switch to the rails on the hill above. That was the difference between going over Monarch Pass and digging through the summit of Monarch Pass. The latter would have been a deal breaker - the line didn’t justify major earthworks.
  2. The Santa Fe (or one of its predecessors) had to climb to the summit of Crown King Mountain in Central Arizona to serve a number of mines and the small town that supported them. It got there by building a ladder of switchbacks up the mountain, including some big trestles and at least one short tunnel. The grade was 4%, the grade of the tail tracks was 2% up from the switch and it took ten (count 'em) reversals to gain a LOT of height!. (Since this is high desert, the roadbed is still clearly visible. Part of it is used by the Crown King Road, which has turnback street corner curves at the sites of the switches and takes little excursions to go around bridge sites and the collapsed tunnel.)
Switchbacks were used on light traffic lines (or temporary alignments bypassing bridges or tunnels under construction) because they were an inexpensive answer to major earthworks, or because they were the ONLY way to get the necessary height. Both the operating and MOW departments hated them, but they were sometimes a necessary evil.
In my own modeling I use teakettle tank locos (and an articulated) to move short trains of light cars on a 4% ruling grade with 350mm radius curves, The terrain allowed me to use single-turn helices where a tighter situation might have required switchbacks.
My tracks are laid on cookie-cut plywood, supported at
There was several short lines that used a shay to climb the mountain to the mine.The C&O used switchbacks to some mines.
As far as a run around at a mine-very few mines has a run around because of space limitations.
These mines was reverse move in and pull out…Even today in Virgina NS reverse moves to several loadouts on the Pocahontas Division.
Hello well I have been working with this and I think I have a plan. I will start at 0’’ and go up to 2.5’’ over 7 feet have a turnout . Go back though the turnout and go up 2.5’’ do this two more time to reach a height 7.5’'. This is where the mine will be. This will give me space past the turnout to the shay and 3 cars. So it will be three up and three down. I will not have room for a run around track.
I have some EZ track I use under the x-mas tree I did some mock ups and I think with the right support It should work out. I have some 1/4’’ hardboard I will use under the track. But I still have some other things to work out before I start cutting up lumber. Thanks for the help and Have a nice day Frank
Hello well I have been working on my short line. I have it just about done still need to add some supports. I Had to change some things but it works out better. I went with a 3’’ rise over 7’ with 4 risers to reach 12’'. I did run my shay a three ore cars and it went up and down with no troubles. Here is a pic of what I have so far.
Let me know what you think ? Have a nice day Frank
YIKES !! just what I’ve been planning to build, I’m starting a logging mountain also and could not figure out what it should look like till I saw this photo (will try to make the flat part longer after the switches), the layout so far looks great, how are you going to fill in the Mountain?? screen or foam? send us a photo of the entire layout , ----again, it looks great ! !
How will you get back there after it is scenicked to retrieve a derailed car or maintain track?
Hello I think it will be foam it will have some straight drops. Looking at it in the photo the edge of the line will be the drops. And the top should look like a mountain. I will leave the left side open a little so I can reach in. The right side that wall is a attic wall I can cut a hole in it so I can reach in.Here are a few pics of the room.
Have a nice day
Hello I made some progress on the short line. I made the rock face from some scrap foam. The cardboard on the back wall is for mock up only. It will be replaced with some thing stonger. And hopefuly look like a moutain when done. Here are some pics.
So what do you think ? Am I on the right track? Does it look like a rock cliff or should I try again. Thanks and have a nice day Frank
Gidday Frank, One of the reasons that I think that this is such a great hobby is how multi-faceted it is. Geology is some thing I know very little about, ( actually one of many things I know little about !!) but am often amazed by “The Force Of Nature”, makes mans efforts look a little puny. That said I am also amazed by the efforts of our fore bearers, who with little more than dynamite, a pick, a shovel, and a wheel barrow, and a whole heap of determination, constructed railways, and or roads, in areas similar to that which you are modelling.
A link to some photos…
https://www.google.co.nz/search?q=rock+strata&hl=en&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=ARHXT4_YH63BiQfxo62sAw&sqi=2&ved=0CGwQsAQ&biw=1600&bih=872
As long as you’re happy with the result, though like Cuyama previously, I hope your track access is suitable ?
Have Fun [:)]
Cheers,the Bear.
Frank,
My dad was an earth science teacher and I grew up with rock formations. The orientation of your strata are highly unlikely, they should all run, more or less, the same direction. In the earlier pictures, I had a hard time determining the thickness of your sub-roadbed. If it is less than 3/8 it is likely to warp. 1/2 or 3/4 is much better. You may still have time to sneak in there and beef it up between the risers. It looks like you are building a really neat layout.
Hello
JaBear I love this hobby for the same resons something new all the time. I also know nothing about geology but we have to try right. Thanks for the link some cool pics.
Markff Thanks I did’t even notice that they were off. I would like to ask how do the strata look as in thinkness ? Are they to long ? Are the gap’s to big/deep. The sub-bed is 1/4 board but I did put in more support befor the foam went up. Thanks for the help Frank
Gidday Frank, As you can see in the images that I linked there are no hard and fast rules regarding the thickness of strata.
Strata thickness depends a lot on what material and length of time each individual layer was laid down, and what elements have weathered them over time, “The Grand Canyon” springs to mind as a good example.
I am of course referring to New Zealand, but on the Southland Plains, where I was raised, the strata layers were comprised of types of sedimentary rock, predominately sandstone, mudstone, greywacke (a combination of sandstone and mudstone), and limestone, I still have a decent sized fossilised shell I dug out of the local limestone quarry as a kid.
Living now on the edge of the Volcanic Plateau, the strata layers are mainly comprised of various types of igneous rocks, and volcanic ash, the thickness depending on the amount of volcanic activity at the particular time, and sedimentary greywacke.
So looking at what you’ve done regarding the thickness and gaps, it looks fine to me,though I am pleased that Mark pointed out, far more diplomatically than I could, that the strata should have the same general orientation.
Keep having Fun [:D]
Cheers, the Bear.
Hello
Mike Iam sorry I spelled your name worng.
JaBear I also have a lot of sandstone cliffs by me. But its hard to get a good look at them. Most of it is covered with plants/trees. I have been looking at them and photos for months and thought it was time to try and make some. I rework the foam so the strata looks straighter here are few pics.
Now I am going to work on the mountain for the back coner. Have a nice weekend Frank
Frank, only rocks I know about is the ones I bought for the flower bed and the one for Miss Cuda Ken.
Only thing I would change is add some lighter colors to high lite area’s in the sun. Other than that, they look fine to me.
Cuda Ken
Gidday Frank, Looks good to me. [tup] [:)]
Cheers, the Bear.
Hello well the more I looked at my mountain the more I did not like it. I have been looking at rocks,cliffs,hills,mountains everything. And you know what mine did not look like any of them. So I tried something else. I found a thread about rock molds. And I like the way they looked much better.So I found a good rock in the backyard and made a mold of it. The hardest part for me was getting the color of the rock right. Here are some pics of the new mountain.
I am still working on it. But I think it looks a lot better now. What do you think? Have a nice day Frank
Hello well I am still working on the mountain. But I am almost done. Few more trees and rocks and it should be done. I also started laying out my farm. Here are some updated photos.
