short reverse sections?
someone told me a story that they hitched a ride with a trucker who sped up as he crossed a bridge. He sped up because his truck exceeded the weight limit on the bridge.
it’s common practice to make a reverse section longer than the longest train. My understanding of this is to avoid the possibility of metal wheels simultaneously staddling the gaps at both ends of the reverse.
but I think the probability of a train having some pair of wheels exactly the distance of the reverse section is low.
So a train longer than the section would cause the auto-reverse to switch polarities many times as one set of wheels or another straddles the gaps at either end. Is there anything wrong with this?
But what if the train does have some pair of wheels at exactly the distance of the reverse section … and is moving?
Would this really be a problem if the auto-reverser is relatively slow to change polarity because it uses a relay, even if it ends up toggling the polarity several times until wheels cross the gaps?
of course a short of any duration is undesirable. It causes excessive heating of electronic components which over time may cause them to fail. Does this mean that there is a maximum number of shorts that can occur before an autodetector or the power supply fail?
So if a long train causes an auto-reverser to switch polarity a dozen times instead of just once undesirable because it can cause an early failure of the auto-reverser or power supply?
is it the frequency of the polarity switches or the time between them that are bigger factors to consider?
I’ve got a short reversing section on my layout. It’s a “crossover,” most easily pictured as a diagonal track from one side of an oval to the other. Trains are frequently longer than the auto-reverser controlled section. I use a PS-REV, the older model from Tony’s Trains / DCC Specialties that has been replaced by the PSX-AR. My PS-REV units are solid state, not relay-driven.
I’ve upgraded my fleet to all metal wheels to improve rolling resistance and keep the track cleaner.
Most of the time, trains roll through the loop just fine. If I watch the LEDs on the PS-REV, I see them flashing a lot if the train is long enough to be on both ends of the controlled section at once.
The flaw in your logic, and the times I have problems, lie with illuminated passenger cars. Even if there’s only one pickup truck on each side, that still means two connected metal wheels separated by an inch or so, which is plenty of time to cause a short and an auto-reverser polarity flip, or a dead short if both ends get this at the same time. Yes, running the train faster may let you coast over these situations.
I don’t think there’s a problem when this happens. I’ve been running mine for years with no issues.
If you do see cutouts where the engine stops, though, I’d avoid running fast. You’re not going to get a smooth slow-to-stop with controlled deceleration, but rather a sharp, jerky stop. This can lead to derailments and even coupler damage as a long train suddenly compresses when the engine stops dead.
I’m thinking of reconfiguring the gaps for my crossover section, to include not just the crossover itself but also the turnout and part of the main. That would lengthen the crossover section.
I have a loop I use to turn trains in Durango that’s longer than most trains thru it. It generally works fine, but every once in awhile, things line up just wrong and there’s a issue. Not enough to worry about, I just give a nudge to it when it happens.
One thing that can help is to stagger the gaps, instead of making them directly opposite. IIRC, this recommendation is even in the PSX-AR manual. Less chance of things hanging, but may not totally solve the problem.
Despite lots of reversing and shorting action, I’ve never had a PSX circuit breaker or auto-reverser fail in action in nearly a decade of DCC action.
The Digital Specialties manual for the PSX-AR also says you can actually double up the gaps at either end, provided the space between these close-set gaps exceeds the length of the longest truck with metal tires/pickups.
You can have MU’d locomotives on one consist with one of them outside the reversed section. The decoders don’t care what they’re getting under their feet, and don’t care if it’s being switched in phase. It stands to reason…if they don’t mind while inside the gaps in a reversed section, the loco outside won’t mind if it gets it rail feed switched under it at the same time.
What you are worried about, or should be, is if a single metal tire bridges any one gap such that the phases are in conflict across that gap. But wait…that’s what the reverser is meant to detect. As stated higher by the OP, the likelihood of two metal tires simultaneously bridging gaps is somewhat low, but it depends on how precisely they are aligned transversely across the axis of the track. So, to minimize the trouble, as someone else pointed out, Digital Specialties says stagger each gap across from each other by about two or three mm. If you double the gaps to handle a long truck, stagger the second set of gaps by a couple of mm as well. That should reduce your risk of a hard short down to less than 0.001.
don’t understand how staggering the gaps helps. can someone explain this more, possibly with a picture?
If you cross just one gap, the reverser knows what to do. It’s either A>B or B>A. If you have two gaps exactly opposite each other, it tries to do both at once – and that’s why things usually stall. It goes into protect mode.
Same thing if you cross the gaps at one end of the reversing section. If it’s done on one side, it may still hang, but the train momentum is isually enough to remove the fault. But if both sides, then it further confuses things enough the reverser can’t sort through quick enough and it then self-protects.
A very non-technical explanation and not a picture, but maybe helps sort it out.
let me get this straight (… you put the lime in the coconut …)
there are two gaps at each end of the reversing section. I’ve assumed that the gaps are exactly across of one another and that both wheels on an axle span both gaps at exactly the same time. But this is unlikely.
more likely is that that the gaps are just a bit staggered (< 1/16") and each wheel on an axle will span each gap at a slightly different time. There are 4 wheels. So there isn’t just one instant in time when there could be a short but at least a couple.
but by staggering the gaps at each end by ~ half a truck length (?) allows the reverser to handle one short without having to deal with another one just after it completes switching.
am i saying this right?
Right on.
Basically, so long as the reversing action has enough time (microseconds) to flip in the reverser, the gap difference need only be quite minimal. Best to add a few fractions of an inch, but the total difference should be less than the minimum wheelbase of any trucks on metal wheeled rolling stock operating through it.
Note that this isn’t absolutely a cure, but it is 99.8% of the time, because some odd combination could still potentially overcome these efforts. If using it on hidden track, then you would want to have some way to monitor things – which you likely would anyway. If you used trains that always used the same rolling stock in the same order, like passenger trains, then once you’ve tested thoroughly going through it, then it should work reliably after that so the issue of watching things becomes less.
In the manual for the PSX-AR, here is what is said about staggered gaps:
When setting up gaps for reverse sections, we recommended that the gaps be staggered about 1/8 “. Perfectly aligned gaps may reduce the current needed for PSX-AR to reverse properly.
since it appears that a reverse section does not need to be longer than the longest train and may become a problem if longer trains are run, what is the smallest feasible reverse section?
the length of the longest locomotive or consist?
this may be a problem for passenger cars that may see opposite track polarity on different trucks which would provide the same polarity (+ or -) on the pick-ups, hence no power. This would be a problem for a locomotive or consist if it were in the middle of a train.
Greg, the section of the PSX instructions we are referring to is meant to cover trains longer than the reversed section…hence the twin sets of gaps at each end.
On my last layout, the one with the helix, I had a reversing side of a scissored turning wye arrangement. My Y6b always tows a train of about 18-22 cars plus a caboose. That was at least six cars longer than the reversed bit. Worked without a hiccup every time.
so there are more that 4 gaps? 8?
I just thought the gaps at each end were offset.
if there are more than 4 gaps and therefore more that one section of track that is separately powered, how is it connected to the auto-reverser?
Staggering gaps won’t change a thing. The short will occur between the rails that are out of phase. It only takes one of the rails. When a metal wheel crosses the gap it can be in contact with the cut ends of both rails at the same time. If those two rail sections are out of phase you get a short, the AR swaps phase and the short is gone.
Problem occurs when the AR sees a short but it is actually ywo shorts occuring at the same time. If those two shorts are directly across from each other, then when phase is swapped, both shorts are corrected and the train keeps moving.
Now in the event of a train crossing the gaps at both ends of a reversing section at the same time, those two shorts will not be fixed. That’s because when the AR swaps phase on the reverse section, it will always be out of phase to the adjacent rails at one end or the other.
So front wheel of engine crosses gap at end of reverse section and a short occurs. AR swaps phase on the reverse section and now the AR section matches the exit section. It no longer matches the approach section. Since some of the train’s wheeels are still in the approach section the next wheel that crosses the gap will cause a short. AR sees it and swaps phase. Now the reverse section matches the approach section but no longer matches the exit section where the train is also still crossing gaps. Short accurs again. As long as only one wheel crosses a gap at a time the AR may be able to keep up. If a wheel at each end makes contact at the same time, AR will keep swapping phase to correct but the train will stop because the resulting short will not go away quick enough to keep the engine moving.
A lot has to happen at the same time, but since it is possible, just be aware that it could happen and the train will simply stop.
Martin Myers
I have four reversing sections on my layout, each controlled by a PSX-AR. I have never consciously staggered gaps. I simply gap each rail, once, at each end of each reversing section. If the gaps are staggered, it is unintentional. I have never experienced a problem.
i’m confused by the inconsistencies in the discussion, including not understanding the rational for the staggered gaps described in the PSX-AR manual
the following seems valid (consistent with what several people have said that they’ve done nothing special and have no problems)
  • a reversing section can be shorter than the length of the train
  • the section must be longer than the longest consist
all that’s required for the auto-reverser to trigger is for just one gap separating rails of opposite polarity to be bridged with a metal wheel
I’m even more confused than Greg.
If someone could draw it all out and explain it, axle by axle, track by track, that would be great. Say the offset between gaps is only 1/8" …I can see that Axle #1 left and right wheels might only trigger one reversal. But doesn’t Axle #2 reverse it again? Then there is the second truck with two more axles.
In a reverse section situation you have three nadjacent isolated districts. The one in the middle is the reverse section. By nature it will only be in phase with one of the sections adjacent to its ends at a time. If a train longer then the reverse section causes a short by having metal wheels cross both ends simultaneously, there will be a short at one end. The auto reverser will correct the short. this causes an immediate short at the other end. The problem flip flops infinitely because AR’s work so quickly. Now by nature a short that continues long enough will trip the booster’s circuit breaker. Now to get the booster back on, you will need to phisically shove the train over the gap so that track power can be restored.
The above is possible with a train that is longer than the reverse section. It may be a rare occurence but it can happen. The exact length of the reversev section and the exact spacing of the wheels need be “just right”. Basically, you are jusr testing Murphy’s Law. BTW, if you run plastic wheels, there should be no problem.
Martin Myers
my original thought was what happens if different trucks on different cars are crossing the gaps at either end of the reverse section. Does a reverse section have to be longer that the longest train? (no)
a train enters a reverse section, causing a polarity reversal. It travels thru the reverse section without causing any polarity reversals until it reaches the opposite end of the section.
a polarity reversal occurs when the wheels hit the gaps exiting the section. But then a polarity reversal occurs when wheels near the end of the train enters the section. At this point, there is a polarity reversal for each wheel set exiting the section at one end and entering the section at the other end.
There are many more polarity reversals in this case than the typical two that occur when the reverse section is longer than the train. But is there anything wrong with this? (no)
The other potential problem are gaps at both ends being bridged simultaneously. In this case, there will always be a short. But since the train is moving, the wheels have crossed the gap before the reverser has sensed a second short immediately after a polarity reversal (especially with a relay). Is this anything different than any other short detected by the auto-reverser? (i think no)
can staggered or twin gaps help this situation in any way? (I thought I understood, but now I see no need).
of course there is a problem if the train is stopped with wheels bridging gaps at both ends of the section. This is a short and the train requires a nudge, so don’t stop.
The most likely time for that simultaneous short to occur and cause the booster to trip is if multiple wheels on the same trucks are electrically connected. As with Passenger car trucks with track power pick up (and engines). This would allow the bridging of the rails to last a longer period of time.
Like I said:it is unlikely but not impossible. The AR also gets one hell of a workout.
Martin Myers
Staggered gaps are not really required for an auto-reverser to react correctly to a reverse polarity situation. The reason that the PSX-AR manual suggests staggered gaps of 1/8" is to prolong the instant of the current reading until both wheels are making contact across the gaps - - - a situation that is most likely to occur on a curve. While a single gapped rail is sufficient for an auto-reverser to react, a pair of gaps may be more effective just as staggered gaps may be more effective.
Staggered gaps separated by more than 1/8" are not necessary and are not any more effective than 1/8" staggered gaps. The most important thing to understand about a reversing section of track is that, once the auto-reverser reacts to reverse polarity by flipping the polarities inside the reversing reversing section to match the polarities of the two adjacent sections of track, the polarities remain matched until the first set of wheels exit the reversing section.
Using “best practices” as a guideline, the reversing section should be longer than the longest train. That best practice will prevent the auto-reverser from reacting prematurely. Unless the layout is too small to accommodate a reversing section of the proper length, this best practice should be followed without exception.&nbs
