Hi all, I’m new to model railroading and also air brushing. I was wondering what the recommendations are pros/cons for either painting my bridge you see in my pic now when it’s about 75% complete or just put it all together and then paint it ?
I was thinking I might have a more difficult time getting the small out of the way spaces if I waited to put it all together then paint… but, then i thought well if i paint it now as in my attached pic i am going to have glue spots or other issues when i go to assemble it ??.. if i did paint it now i would take all the remaining individual pieces you see and remove from their modeling and paint them all individually before final assembly a bit of work but thought i would be worth it…
Just wanted input from those with years of experience
Paint when done. I did a much more complicated Central Valley kit and it worked out fine and with rattle cans even. Just need to be carefull and with an airbrush it should be even easier.
great! thanks for the advice… i have done my research on video examples for airbrushing. i’ll test on some old plastic stuff lying around first until i get the hang of it… take my time, quick fast strokes, light coats, maybe 2+ of the light airbrushing … avoid stopping or holding the airbrush in places of course. I think i got it, was just wondering on the before or after bridge assembly, after sounds fine to me.
I recall reading an article on building a steel smelting works, on another online source (due to the rules of this forum I cannot refer to the site).
The builder painted the sub-structures during assembly, then did a final coat of the finished structure.
Because this was an extremely complicated build the paint-as-you-go method was employed for maximum prototypical effect.
When you paint any part of a project remember that the paint will typically “seal” the bonding surfaces so cleaning the area will produce a superior bond.
This holds true for styrene and wood- -with some exceptions- -of course.
When I built a bridge out of wood I stained the individual members before assembly because the carpenters glue would inhibit the stain from reaching the wood and create unwanted masking at the joints.
In the August, 2019, Model Railroader magazine; pg. 38-43, there is an article on a bridge build.
The modeler pre-painted some areas before final assembly and then “finished” painted the completed structure.
Please keep us apprised of your build and as always…
I also built the Central Valley truss bridge. I did all the assembly first, and then painted it with a rattle can. It came out just the way I wanted it.
But, it was all a single color. I also built an older Atlas chord bridge. This had wood walkways and metallic handrails, so it got done in several steps before final assembly.
There is more than one way to skin a cat they say… I like to wash all the parts on their sprues, let it dry, and paint the base coat using the airbrush without taking off the parts from the sprues. Now in the case of a bridge, the base can be a grimy black or green color (look at the pictures on the Web…). I painted mine a rust color, assembled it, and painted it black with the airbrush, but not totally, leaving in some tints of rust. In all cases, it’s a lot easier to give it a base coat before assembly. You just need to scrape off the paint where the glue will be applied. You can do touch-ups after the assembly - which is why I don’t weather the parts before assembly.
You might consider spraying the pieces - even if still on the sprues - beforehand, which will cover most of the surface area. Upon completion of the model, you can touch up the base color, and then do whatever weathering you like.
I’ve found that using a rattle can of good model paint - which the same color available in bottles - makes painting the finished model much easier.
I suppose the adhesion of whichever glue you intend to use could be a factor. Will styrene glues work well when the mating surfaces have acrylic or oil-based paints on them? Dunno. How 'bout ‘as well’?
If a person knows there could be a reduction in efficacy with painted surfaces, one could possibly scrape or roughen some of the surfaces to be bonded? Extra work, and it might ruin more of the painted surface than you intended.
Handling the parts and gluing them means you could leave hand oils and acids on the surfaces that you later will want to paint. That can’t be good. However, one more chore would be cleaning it all somehow, and not breaking fine details while doing it. And thence to paint.
Some parts need to be painted before assembly as they are too difficult to paint in place either with a brush or airbrush. Just take time and make sure you don’t paint the bits that need to have glue on them, it can make for a[D)] moment. I have spent time with file in hand removing paint where it shouldn’t have been.
[#welcome] to the Model Railroader Forums, thanosazlin!
Painting the parts before assembly will make it difficult to get a good glue bond, unless you scrape-off the paint where the solvent-type cement will be applied. Some folks opt to paint first, then assemble the parts using ca, but a joint made with solvent cement is a much stronger (and neater) bond.
Each of the bridges shown below was built as a single assembly, and then painted using Floquil paints and an airbrush. All were too large for my paint booth, so were painted outdoors. All bridges shown are removeable as one-piece units.
The tall bridge in the rear is all Micro Engineering parts, while the one in the foreground used two Atlas deck-type truss bridges, and Atlas through girder cut apart and modified into a deck-type, along with some Micro Engineering deck girders…
…this one is mostly Micro Engineering parts, along with two Atlas deck trusses…
This one used two Atlas deck trusses, plus a Micro Engineering short deck girder, hidden by the trees in this photo…
…but visible here…
The first photo, below, is the west end of the Maitland River bridge, with a 30’ deck girder at the far end, followed by a 50’ deck girder (both from Micro Engineering), and another Atlas through girder, converted into a deck-type (the LHS had a bunch of them, used, for a couple bucks each, so I bought 'em all. One of them ended up as
My procedure for through truss bridges is to paint them black prior to assembly, then paint them the final color once fully assembled.
If the final color is black, I use a mixture of four parts black, one part white, and one part red to get a color that looks like black under indoor lighting.
The Central Valley bridge is molded in black, so the step can be skipped.
Any part left in the black preliminary coat in the final paint will look like shadows in the layout room.
