Please help me through a senior’s moment. What is the proper name for LEDs that have a concave hollowed tip. These are the ones that are designed to distribute the light to the sides instead of projecting it out front.
Thanks[D)](brain fart - you know the feeling[(-D])
You can also get even better results using standard 3mm LEDs and lightly sanding the entire surface. This diffuses the light and causes the entire case to illuminate.
I am currently working on a Bachmann street car which I want to convert to DCC. The car comes with an interior lighting molding cast in clear styrene. The molding provides lighting for the headlight, tail lights and the interior. I have already separated the head light and tail lights from the molding so I can illuminate them with LEDs but I want to see if I can use the rest of the molding to illuminate the interior as was the original intent. I need to get the maximum amount of light into the molding to make it work. Sanding the LEDs sounds like a great idea.
