I don’t know why this image did not copy. I do not want to confuss you. When I said I created the circuit on my bench, it was not the one that went to the layout. The LED’s were hooked directly just like the one, so I see if the circuit worked. Then I used another board on the layout. My next step if I do not find the cause is to take it apart and start again. I made sure I did not solder any wires until I saw it work.
Well, I think the “signal” is just the IR pair on the board, right? Or are they extended off the board? Signal or no signal you should get the green light, right? Sorry, not that familiar with these other than reading up on web[:$]
OK I see one version has 18" leads, and one has IR Pair on the board itself. Which do you have?
I did. I have just taken the IRdot-1 from under the layout and checked the connections. They are all in the right place. Over the weekend I am going to first run power to the LED,s in the signal to make sure they are working and built a new IRDOT-1 just to make sure it does not have a bad component. I will let you know how it turns out.
Now I am completely confussed. I hooked a clip to the positive side of a 12v Reg DC. I then hooked the other end of the clip to a 1K resistor. With another clip I attached it to the other side of the resistor. I connected the negative side of the 12v to my meter.
Tested voltage at the source Read 12v
Tested at the power side of the resistor Read 12v
Tested on the other side of the 1K resistor Read 12v
Tested at clip at bottom Read 12V
Why am I not seeing a voltage drop?
The red LED is no longer working.
Last week when I was going to see if a LED was working I hooked it direct to the 12v supply and blew the H out of it.
Doesn’t it mean 12v is going to the LED? Or does it drop the voltage through the LED?
The signal is now on my bench and the red LED does not come on. Tested as above through a resistor Before it was installed on the layout I had tested it and it worked?
No, the LED needs about 3 volts, leaving 9 left over for the resistor, which is where the current calculation comes from. 9mA - 9 volts divided by 1000 ohms. A meter by design puts as little possible load on the circuit as possible, so as not to influence the circuit under test.
A simple check for red and green LEDs is with a multimeter on the lowest range (ohms) across the LED leads. There is enough voltage coming from the meter to make an LED glow.
I bought a cheapo A830L meter off eBay for my hobby needs and it even lights up white LEDs on 200Ω range.
