I have read over the years articles by Tony Koester of how he scratch builds his turnouts and his use of “silver bearing solder”, especially when soldering the frogs. I am thinking of taking a stab at doing this. I’ve looked up that type of solder and see different types…some have flux built in, others don’t. Some have varying amounts of silver in them. I have the MR issue that featured his article on making your own turnouts. But even that doesn’t seem to go into detail about exactly the silver solder that he uses. Does anyone who has built turnouts this way have any suggestions on which is the best type to use for turnout building applications? Also, where to buy it and a tradename to ask for?
I have no experience with silver-bearing solder to build turnouts, so I am not your best source. I do, however, have some experience with it as an HVAC technician. We used to use a brand called Stay Brite 8. It is a very good and very strong solder.
Your question is based on the assumption that Tony is right. That’s not necessarily so. Solder with silver is claimed to produce a stronger bond, but in reality, both types are significantly stronger than you need. I’ve built turnouts using silver free solder and never had problems.
Fast Tracks is the leading supplier of tools and supplies for turnout building. The solder they put their name on is good old 60/40 - no silver.
I bought some Silver Solder for a turnout building exercise a few years ago.
MG Chemicals, 4900-35g. Lead free, no-clean. Doesn’t show up on their website.
This is the 17 gram package, 21 Ga wire in a tube dispenser. They do have bigger quantities. Their flux is also excellent. Their products are available at any electronic distributor, like Mouser, Digikey, etc. I bought mine at a local electronics supplier.
It may be a little stronger, but it also takes more heat to melt. I’ve only used for turnout construction (strength) or modifying/building a shunt (heat!)
I have two types of silver-bearing solder, one as a paste and the other as a reel of solder. While the bond may be stronger than the lead/tin variety, it’s not used in a manner that would test the strength of the bond. Both are from Kester, and perform as well as any ordinary solder.
Thanks to all! I have never attempted to build a turnout from scratch, and am always interested to learn how others have done it, and what their techniques are.
It is easy to fall into a trap of one method, but I am a believer in doing it yourself with materials you have at hand. I have been soldering on my layouts for over 50 years and always use Kester products, because that is what I could get at Radio Shack. Now that they are fewer, it may be harder. I will probably have a go with what I have, and see what happens.
Silver bearing solder has a lower melt point than 63/37 solder by about 10 degrees. Most 63/37 melts at about 361 degrees. Not enough differance to make a big difference IMO. I have not built turnouts with the silver bearing solder but I do use the 62/36/2 silver bearing solder for DCC installs. Melts at 352/354 degrees. The temps listed here are from Kesler. I find that the silver bearing solder flows better. But that is MO.
Yes, the 2% silver content is one of the [very limited] versions that do have a melting point that’s less than 60/40 … however, most silver bearing solders [and especially lead free solders] do have a higher melting point
Part of this is to know ahead of time what type of material you want, and some of the specific tech and savoir-faire involved with it. For example, you’ll probably want to use a good flux, and I’d recommend that should be a no-clean flux whether or not you try to do ‘proper’ joint clean-up afterward.
Sources catering to the jewelry industry, where fabrication often involves careful sequential choice of solder with differences in liquidus point, are one good source of information (see for example Halstead’s). I mention this because too much target focus on ‘hobby’ soldering will miss this.
I have found that many of the solder suppliers provide technical material to help you understand how to use their products more effectively. For example, a good source for low-temperature soldering rather than brazing is SRA, and they have a special ‘resource center’ accessible from their Web site
Thanks for clarifying that. I have been using Kester’s 62/36/2 solder for years and your comment made me question my choice. I have never had a problem with it flowing quickly. In fact, with my newer Xytronic soldering station it flows almost instantly.
As far as strength goes, I have had to buy extra strength solder for the points on a couple of switches that kept coming apart. Maybe not necessary in the frog but might be helpful on the circuit board throwbar soldering joint. I didn’t need this for all of my circuitboard throwbars - just a couple of them.
