I was thinking of a way to add very simple signal control to an HO modular railroad. Because it is modular, with each module owned individually, it is very unlikely that there would ever be one standard signal system to hook up to thus creating normal blocks. But it’s often annoying to see the same signal color all the time, especially when set up for shows, etc…
So I started looking around online and found an interesting product by Circuitron, called SA-1. This is a selected quote from Circuitron’s catalog:
“Complete, simple, signal detection with timed 3-Color signal animation. Signal turns red as train passes. After last car clears signal, adjustable time delay starts (0 - 30 seconds). After time delay completes, the signal turns yellow, after another adjustable time delay, the signal goes back to green.”
It uses light sensitive sensors mounted in the track. So no need for resistive wheels like you need for current detection systems.
So this sounds great. Especially when most modular display layouts run trains in the same direction and in plenty of light so the sensors should work fine.
However I have an extra requirement. In addition to the 3 colors, Red, Yellow, and Green. I would also like to have Flashing Yellow. So it goes, Red, Yellow, Flashing Yellow, Green.
But so far I haven’t found any systems that can handle this without using a large interconnected block signal system. Obviously something that is not practical for a multi-modular layout.
I even emailed Circuitron asking about Flashing Yellow, but have yet to receive any response.
So does anyone here know of such a system? Where it doesn’t depend on blocks to change a signal, but also includes Flashing Yellow?
I plan to use the new
