I started to make a full scale drawing of my track work now that the benchwork is up, the foam is cut, trimmed and glued down. I have a track plan drawn to a much smaller scale. I tacked down white poster board on the layout, thinking to draw the track plan at full scale. I made a trammel with two pencils jammed into it, so it will mark the inside and t he outside of the curved track in one swoop.
Then I started thinking. The layout is an around the walls job. The main line is a loop, and to save space and permit guests to use the guest room, the bench work is only 6 inches wide on two walls. The original plan was a single track loop. But looking at the situation carefully, I could fit a a second track onto the benchwork. My first thought was to add some long passing sidings that could serve as staging tracks.
Then more extra credit, I could double track the main all around the layout. This would permit two trains to circle the layout in opposite directions, for those times I just want to be a railfan watching the trains do their thing. With a single track, you have to actually pay attention and operate the layout to get a second train to run. A stimulating challenge? Or a PITA in the long run? So that gets me up the 5 o’clock and Miller time. We shall see what thoughts the morning brings.
Any feedback from out there in the great wide spaces of the Internet will be read carefully.
Double track is better, especially if you’re showing off the layout to guests. With guests, you can let two trains run without attention, showing off something else.
The second track could definately provide some serial staging space and with a few crossovers it could have some flexibility. But let’s see:
6" wide shelf. First track centerline 2" from wall. Second track centerline 4" from wall. That leaves only two inches from the second track centerline to the edge of the shelf. (HO scale assumed)
My concern would be - what happens if I get a “tip-over” on the outer track? Your train is definately going over the edge. You could line the edge of the shelf with a clear pelxiglass guard. Just a few inches high would be all you need.
I am very strongly biased towards double track main lines, where trains mainly run only one direction on each track, usually the right-hand track. Most of the main lines where I grew up were like that. Then the RRs started pulling up the second tracks in many areas. Now, with increased traffic, many of them are rebuilding those second tracks at great expense. The reason for my bias is safety - positive separation of opposing traffic.
Accordingly, my model RR is a double track main line oval, with crossovers and a reversing loop. I also plan a passing siding off the outside loop and a couple of small yards off the inside loop.
I’m not saying I will never run a train the wrong way (on the left hand track), but it will be only to make a transition of some kind, such as to use the reversing loop or get to the yards.
With just one train running, guests would see your layout and not just the trains. You would also have more room to put in some industries and switching oportunities. One of my layouts was a six inch shelf around the room. In one section I dropped the shellf down about six inches or so for about a foot and put a bridge across it. You could also do the same thing by using foam blocks to build up a mountain with a tunnel or cut. The part of the mountain facing the isle could just be flat and covered with a facia sheet and painted the same color as your other facia, if you have one.
Just because you only have six inches of width doesn’t limit your scenery and industries all that much. It will make you more creative if you can figure out how to use such a narrow space. Work on a good backdrop using photos or drawings from on-line sources that you can print out. Build building flats for industries. Model small things as well, such as a section house with tracks for a speeder. You can still put in the appearance of a road or two with a grade crossing.
Both. Make a double track main line. Put crossovers to make where the passing sidings would have been on a single track main line. That way it can be operated either way.
I did that and in a section where the main line went into a mountain, I had it cross as it came out so that even though it looks like a double main line for 80% of the layout, it really takes twice around to cover the entire mainline… Crossovers exist also in case I want to run on just one track of switch between track sin another area.
Podnah. unless I missed something you give no compelling reason for why you are restricting your shelf width to 6 inches but I wouldn’t try to construct a double track mainline on that depth in N-Scale, let alone in HO-Scale. That 6 inches is going to restrict you to flats against the wall for your structures and that is going to lead to monotony.
If your shelfwork is only 6" wide in a few spots because of space consideration, you can still model a double track line. But I would go for 12" or 16" as much as possible - if nothing else it allows you to have the mainline going at a slight zig-zag rather than parallel to the benchwork edge all the time.
One advantage of double track is, if you operate alone a lot, you can have say a passenger train running on one main while you work industries with a way freight on the other, and the passenger train won’t interfere with your train.
I am a firm believer in double track. Being someone who operates trains primarily to watch move and not so much prototypical car switching/etc, I can watch two trains instead of one. I can “race” them with each other or just watch them pass in opposing directions. I love my double tracks.
My present HO 11x15 layout is a single track main. The layout is 15 years old and I kick myself for not putting in a double track main to start with. Preliminary plans have begun for the rebuild (probably my final layout as I am 63) and a double track main with crossovers are a must. One thing to consider is that you don’t have to have the double track be parallel all around the layout. You could have one line divert around obstacles (mountain, river, etc) and rejoin each other on the other side. A lot of this occurs with the prototype western RRs.
Stop for a minute and think about how you want to run your railroad. If your goal is to have lots of action and trains running merrily about, then double track is your answer. I’ll agree with the notion that 6" ain’t going to cut it, though. Remember, if you’re talking about a full double track loop, you’ll actually have four tracks shoulder to shoulder where they run along the wall.
You could, however, do a “folded dog bone” where you have what is essentially a single track oval, but it’s pinched in the middle to give the appearance of a double track main. Depending on the length of your overall run, you can still run two trains at the same time, just space them so they aren’t running into each other. This is best accomplished with DCC, where you can control the speed of each train independently without worrying about block control.
I’ve done this design in the past, and used the loop areas to add staging tracks.
If you’re thinking about prototypical ops, then consider the single track with passing sidings. This makes things a bit more interesting as you have to work out meets at the sidings, and set up a sequence of how the trains will emerge from staging and traverse the layout.
My previous layout was a single track mainline with passing sidings but I went with double track on the current layout because I wanted to keep things moving. Each has its advantages. I’m not sure I remember where I read this, possibly from John Armstrong, but the recommendation was double track was good for small layouts since the main line is so short you would be constantly running trains just a short distance before they would have to wait in a siding if you single track. On the other hand, with a longer main line, a single track which forces trains to do meets and passes can add a lot of operational interest and a challenge for the dispatcher if that fits into your scheme. If operations are not your thing and you just like to see trains running, double track is probably a better choice. Also, the era you are modeling could influence your choice. Many modern day prototypes are now running single track over what once was multiple track lines. Am I right that Horseshoe Curve which was one a four track main is now single tracked with sidings. From the railroads perspective, single track lines require half the mainatenance.
Actually Horseshoe is considered double tracked with a “controlled siding”. During PRR days the line was four tracks (hence the Broad Way) with the outer tracks being the passenger mains, and the inner tracks the freight mains. During the late 1980’s, Conrail eliminated the eastbound freight main, or Track 3, leaving a gap between tracks 2 and 4.
This view is at Cassandra, PA, several miles west of the Curve, looking east. The train is on what was the westbound passenger track, now the westbound main.
