I am converting some of my old loco to DCC the wire is thin what gauge wire should I use I found some 22-gauge but don’t want to buy it if it won’t work for installing decoders. Cn someboody make a suggestion? Don’t want to spend money on something I can’t use.
I use 30AWG ultra-flexible wire, which can be purchased from Miniatronics. It comes in a variety of colors so that you can color-code your decoder installations - i.e. orange & gray for motor; red & black for rail; white & yellow and blue for headlights and common; purple & green for auxillary lighting effects; brown for speakers. I picked up the multi-color bag of wire rather than purchasing individual spools. It contains enough wire to do several decoder installations.
Along with that I would also highly suggest that you pick up Kapton (polyimide) tape. It’s very thin but holds down wires extremely well and doesn’t leave a residue like electical tape will after a while. It’s also great for insulating the backside of the decoder so that it doesn’t inadvertently short to something, like the frame. I find that the 1/2" width is a good size. It’s not inexpensive but a small roll will last you a lifetime.
I use either #28 stranded rated at 226ma or #30 stranded #30 rated at 142ma. The smaller the better for inside locomotives. Short runs 6” to 10” can handle more current than the rating. Most decoders come with #28.
I have Athearn Gold motors in a lot of my locomotives that draw one amp locked rotor and never had a problem with #30 wire.
I’ve been using #28 for my Athearns for many years without any problems. I put a ½” loop between the motor and the trucks for added flexibility. Probably doesn’t need it but it looks better when I swivel the trucks.
Mel
This is what I use too. The advantage, for me, is that it has each standard DCC decoder colors. I often rewire the entire loco with the standard colors. Red and black to the power pickups, Orange and Grey to the motor, Blue, yellow and white to the lights. This makes it much easier for me to understand what goes where in the loco if I have to troubleshoot it later.
