First off, motor performance has a few factors involved; drive friction, decoder quality and decoder settings.
I would buy high quality locomotives OR upgrade olderlocos (such as remotoring old Athearns).
I would then buy high quality decoders (look for catch phrases like torque compensation, BEMF and 28/128 speed steps).
When programming, select the locomotive with your handheld and set it to speed step 1. Then adjust CV 2 so that the loco is crawling at about a tie every dozen seconds or so. This is a great start speed.
Then adjust CV 5 to set the top end. CV 5 is a great CV to set when you are speed matching. When you set CV 5, CV 6 (defaut is usually zero, or off) is egnored. If you want to include CV 6, then go ahead and set it (CV 6 controls voltage to the motor at mid speed).
After you have set CVs 2,5 and 6(optional), then set CV 3 and 4 (Acc and Dec momentum respectively).
In terms of motor frequency, I havent needed to play with that as of yet.
First of all, a locomotive has to run slowly and smoothly on DC. DCC control does not improve the running characteristics of a locomotive. CV adjustment allows you to adjust how you control the locomotive, but it can’t turn a poor runner into a good runner.
If you want to improve your locomotive’s running yourself:
remove the motor and worm(s). Does the mechanism roll freely and smoothly on a glass plate? If not, find the binds and fix. Often gears will have burrs and flash. Bearings and gear boxes can be dirty or full of old caked lubricant. Steam loco side rods can be bent and/or drivers out of quarter.
Can you hold the motor in your hand while it’s running, or does it vibrate too much (out of balance or bad bearings)
use the current draw as a measure of how good things are/aren’t. A loco with an open frame motor should get down to 0.6 amps or less running by itself. Weak magnets, as well as binding mechanisms, can cause high current draws. Magnets in open frame motors can be easily replaced with rare earth magnets, reducing current draw and increasing torque. Can motors will draw less current, typically in the .25 amp range for HO scale.
If the locomotive is running properly, is the gearing and/or motor RPMs too high? Increasing the gear ratio will improve slow speed running, while decreasing top speed at 12 volts (usually a good thing). For my era and prototype, gearing for a top speed of 45-50 smph helps with low speed performance.
Can’t really help with individual CVs. But a steady creep of less than 5 smph should be achieveable on straight DC in most all locomotives. Once you have that, fine tuning the CVs to meet your desires shouldn’t be difficult.
fwright great post. What I’m getting is that people don’ adjust their loco’s CV’s they take what is given. I noticed from other post that this post is a mystery to most members. I have some friends in the hobby that can extract max performance out a box the loco came in. Just as soon as I learn to do this I’m going to share these technics with the forums members.
I recently put a QSI chip upgrade into a BLI Hudson and BLI Mike and the low speed response is like day and night. I am really impressed with the QSI upgrade chips. The engines accelerates smoothly and run very well.
Recently I got 2 Stewart switchers and put TCS MC2 chips in with BEMF. I had to turn off the BEMF because the locos started too fast on Speed step 1. I adjusted Dither to just turn the flywheel on speed step 1 and now they run great. Nice and slow. 5 minutes from 1 tie to the next. Sometimes locos run so good that I have to adjust CVs down to get them to run like the prototype. Then you get other locos and have to adjust CV2 to 24+ to get them to turn over and CV6 to keep them from flying off the track. Gear ratios play a big part of speed matching locos I just wish manufactures would standardize or just come close to each other.
