slowdown on 2nd train on same track
am trying to find the story on how to run 2 trains on the same track without them running into each other. if anyone knows where I can find this story I would appreciate the info
Well, first off, there are signals regulating the movement. But if you mena close to each other, then it would be radio blocking.
IF I understand this question, yes, a train can “creep up” on another train in a block,but they can only do so at a speed that will permit them to stop in time to avoid a rear end collision with the train ahead of them. CSX, NS and UP have had to do this a lot in recent times. I recall having seen the Conemaugh line (PRR) from Kiski Junction, all the way back to South Fork filled with trains that had to be parked until room opened up for them. NS cleaned up their act, but, CSX and UP ? You two have a lot to do, yet. In NORAC territory a form D, or C-1 will be issued for the protection of both trains by the dispatcher.
am talking about model trains not real trains
You need to learn about DCC that allows you to control up to 9999 trains on the same track independently of each other.
I run DCS all the time can contol several trains at one time on one track but you have to be quick or major wreck time . The most I can manage is 2 at one time…G scale
50 car trains
Max if there are signals they dont use radio blocking.
first off…you need to be asking this question on the model railroad part of this forum…secound…your question is so veag in its wording that no one realy knows what your talking about…
csx engineer
