Smoke for my DCC train
Hello everyone. I have been rerading the posts and threads in the past about adding smoke to engines. I thought about amperage etc… I have a few of the Rapido “Oh so steamy” smoke generators and I was wondering if anyone knows how to wire them, or if they at least will wire into a DCC decoder function or do they have to go to direct track power.
The first thing you must determine is the current draw of the smoke generator – it may be beyond the capability of a decoder. Most decoders are limited to 250mA current draw.
Most serious modelers abhor smoke because it leaves an oily, sticky residue on everything.
I know that smoke can be a bad thing. The Rapido claims in the paperwork state that the smohe will help “clean” the track. I said the heck with it last night and placed it on track power. The smoke doesnt stink that bad (at least not anywhere as bad as other smoke fluids) and I didnt feel any smoke residue left behind after testing. Now let it be said my carpal tunnel has been pretty bad lately so I just might not be feeling it.
I think Rapido probably means the same thing as AristoCraft, who touts their smoke fluid for use as a track cleaner; but it’s still oil based and is going to leave a sticky film on the track that will just attract more dirt. The “track cleaner” claims mean to use it in place of another product; not that it will clean the track as you run.
The effects of using smoke will not appear immediately, but will build up over time.
A few years ago a chemist who is a model railroader diagnosed several different brands of smoke fluid, and reported that practically every one of them was mineral oil with different scents added.
His findings were reported in the Garden Railways Magazine forum.
Just leave the smoke switch in the off position on your smoke generator car and push the “pretend” button in your mind instead. Your track and any scenery will stay cleaner longer.
I, personally, would not use smoke as no smoke on any scale model train, no matter the smoke generator make or model, will ever look even 2% prototypical.
The modern sound presentation, at its best, is getting really good at being prototypical, smoke trailing like off like a nearly finished cigarette just spoils the impression of good sound.
Smoke is fine for large scale toy trains as it is traditional and goes along with the toy impression and look as the trains move about at 100mph on 10 inch radius turns.
For many folks working in a serious scale environment, smoke, as currently presented is a buzz kill.
But…To each his own…
Richard
Well… This seems to clench my decision regarding smoke usage… NOT such a hot idea. Thank you all for your input. I guess that it is time to loose some Rapido smoke generators…
Hi all,
MICP3389, welcome to the forum!
I would tend to agree that the Rapido smoke generators are probably not worth the effort. Their smoke output is pretty anemic, and while I’m not certain, I think it likely they draw too much current for most decoder function outputs.
However, some of the comments on this thread reflect a lot of “common knowledge” that is now out dated.
Originally posted by: cacole
“Most serious modelers abhor smoke because it leaves an oily, sticky residue on everything.”
Originally posted by: narrow gauge nuclear
*“*I, personally, would not use smoke as no smoke on any scale model train, no matter the smoke generator make or model, will ever look even 2% prototypical.”
Most folks in HO got their experience with smoke units from either O-gauge Lionel or Seuth type smoke units in HO or other scales. Neither is ever remotely representative of a quality modern smoke unit. Most of the complaints about residue getting on everything come from the Seuth type smoke units. They actually boil the fluid in a heated pot. Just like an uncovered pot on your stove, a Seuth smoke generator will splatter fluid all over the place. They really do cause a huge mess. The other complaints that the smoke is too weak and or thin to look prototypical were certainly true of postwar Lionel engines. You had to get them running at 100+ scale miles per hour to ever get much more than a wisp of smoke. Today a lot of old fashion smoke generators run off constant voltage power supplies, but they still don’t make much volume.
However, Lionel, MTH, and a few others have broken through a lot of the technical barriers in recent years to produce clean operating smoke units with remarkable output volume. Here’s the photo that I use as my Avatar.
I must agree, Dave has a point. Things get better over time. G and O gauge smoke gens are getting better and that large boiler volume HO, 4-8-2 was a bit better than I have personally seen in the recent years at train shows and the like. However, small boiler HO and certainly HOn3 stuff can’t sport that kind of smoke generator yet. Most small HO and HOn3 boilers are 100% taken up with a large lead plug for tractive effort. It’s still puff puff or whimpy trails of Cigarette smoke for the smaller engines if you insist on smoke. Just like sound, though, smoke will come and at a price comensurate with its realism.
Right now, for all but the largest scales, smoke is where sound was in the 90’s. (Not there yet)
Since all smoke, regardless of origin, is a mass of microfine particulates, the long term effects of voluminous smoke that mimes realistic operation on our track and frequency of cleaning has yet to be seen. All this awaits a future tale borne out of experiences. It is proper to be concerned about this. One automatically assumes that the smoke making chemical and its vapor has been carefully chosen to be both non-toxic to breathe and non-corrosive in the presence of moisture once settled out on stuff, especially if there is going be be a whole lot more of it to mime realistic operations.
I can readily envision fabulous smoke pouring out of advanced smoke gens in G gauge garden layouts where fresh air abounds and track maintenance is more about acid rain issues that a smoke film on the rails.
Richard
Better, yes. OK, so it isn;t spitting bits of smoke fluid all over - but that cloud of smoke does and will condense and then what? Smoke fluid all over, same as before. Maybe it’s not the same material (mostly mineral oil) as before, but it’s still oily and has a tendency to attack plastic.
The plumes of smoke on modern models are pretty impressive, especially properly synched with the pistons. But somethign is still not right - it’s too clean. It’s like pure steam, as if the fireman had the absolute most perfect fire going producing zero soot. Even on a very well fired loco, that produces little more than a heat blur above the stack when standing still - when it first gets moving, it sure does clean all the soot out of the tubes. The only palce I’ve ever seen pure white model type smoke come out of a steam loco is the cylinder cocks and the turbogenerator exhaust.
And then to stick a smoke generator in a diesel loco as the exhaust, not to represent a train heat boiler… Granted, Alco diesels were “honorary steam locos” because of the way they smoked it up - but it was a black, sooty smoke, not white like steam.
Those old Seuthe smoke generators were great for an industral plant’s steam boiler, or a house chimney - or a standing loco. The new fan driven loco smokers definitely are a step in the right direction appearance-wise. But they still DO get a film all over everything when used frequently.
You know, I hear people proclaim the horrors of smoke fluid accumulating everywhere and I have to question how much really experience these people have. I received my first smoke equipped locomotive for Christmas over 25 years ago. It was a Lionel O-gauge set that didn’t make a lot of smoke, so it never caused a problem. In my teen year I moved into HO, which didn’t have smoke in those days. Then in the mid 90’s I was attracted back into O scale by the quality of sound, smoke, and control features. I purchased my first engine with a fan driven smoke unit in 1996. It produced copious amounts of smoke, but it was well vaporized. I never had any traction problems or problems with oily film accumulating anywhere. However, my set up was not permanent and my running hours were limited, so one could discount that experience. In 2002 I started building layouts professionally. Over the last ten years I have built indoor layouts in N, HO, and O, along with outdoor layouts in O and G. Some of these layouts operate smoke equipped engines on a regular basis and some have no smoke equipped engines at all. There is no noticeable difference between them. There’s no noticeable oil build up or extra dust accumulation on the layouts that run smoke. It’s just not an issue.
So where do these horror stories come from? I don’t suggest that people imagined this out of nothing. Rather, I think people have taken the short comings of earlier smoke units and turned it into a conventional wisdom that no longer holds true. If your only experience was a Seuth type smoke unit splattering fluid all over a boiler shell and onto the track i can understand having a bad impression. They make a mess of your engine and deposit enough fluid on the track to cause real traction problems. Objects that get a thick coating of fluid will hold dust. But a good smoke unit that vaporizes the fluid without splatter never deposits a t
Dave,
Again, I want to say THANK YOU. I have thanked you in the past on another forum for your Generous help in wiring some crossing gates, now I Thank You for dis-spelling these continued, uninformed MYTHS, about smoke units in model railroading. You put it in words much better than I could have, Hopefully coming from someone with your credentials, perhaps at least some will re-evaluate the value of Quality smoke units, sadly, I’m sure that some will never accept the progress that has been made in this part of the hobby.
Thank You (Again) You are truly an Asset to the Hobby,
Doug
Not sure what BRoadway Limited is using for their smoke fluid then, as since they stopped including a small funnel to make sure the smoke fluid goes intot he smoke unit and not just drips down inside the loco when you refill it, there have been many reports of having to send the loco back for service as the smoke unit stops working. Not from runnign dry, but rom the smoke fluid getting into the motor and fan assembly and causing the plastic fan to get loose on the motor shaft and no longer spin when the motor spins. It didn;t happen with their first smoking loco, which cam with the funnel, but all subsequent models like the T-1 which did not come with the funnel have had this issue
Doug,
If I were operating my steamers outdoors, I would probably try the smoke units out. However, since I prefer to not breath in mineral oil “smoke” in my small basement, the smoke unit on my steamers will remain in the OFF position.
Smoke - nor the lack of it - enhances my enjoyment of the hobby. I can just “pretend” it’s there and be perfectly fine with that.
My only recent experience with smoke comes from the Amherst Model RR “Springfield” shows I’ve been to over the past few years. The whole room near the MTH booth smelled of smoke, and it was pretty unpleasant. Given that this was a large show venue with high ceilings, I would be very reluctant to use a similar system in a typical layout room.
The higher volume of smoke from the MTH units may look better, but the more smoke you put into the air, the more particulates and irritants you put in as well. I just can’t see this being anything but bad for you.
I would be happy to choke on a ton of smoke and put up with its foulness and possible other nasties if only they made a nice super high volume cam controlled smoke unit that would fit in my 1/2-inch inside diameter, by 1 1/2-inch long HOn3 K-27, K-28 boiler volume. Not there yet nor will it be for a long time, i bet. If I ever see one, it will be bought on the spot, regardless of price! Needless to say it will stay turned off for 95% of any run time. Just there for photo and live video applications and a few visitors.
It would be great to have massive clouds of full scale smoke rolling out of my k-27, K-28!
Meantime all you big boiler volume guys have fun with those modern smokers.
Richard Hull
The last time I ever visited a large, permanent club layout in Tucson, Arizona, they had signs at the entrance warning potential visitors with any type of respiratory problem that there was smoke being used and they would not be admitted.
I don’t know if this was because of a warning from the Arizona Department of Environmental Quality or a result of a threatened lawsuit.
I never go to such a venue because the smoke causes my eyes to sting and burn.
You’re lucky if that’s all it does. There’s a train show held twice a year around here and the large scale guys always have a set-up with something or the other smoking. I have to stay away from that area because it makes it hard for me to breathe.
And down a our HO club someone brought down a smoking engine and the stuff dropped down under the benchwork until it found a place to come up in an operating area. Same result on the breathing impaired.
Hi Richard,
You might not have to wait. I took a look today at an MTH smoke unit I picked up from their parts booth at a train show. This is the same unit they use in all their larger steamers, like the one in the video I linked to earlier. The main body of the unit is .582" in diameter and 1.332" long. If one of your boilers is a little over 1/2 inch you might just make it. There are some plastic nubs for screw mounting that would have to be filed off, but it sounds like your engine would be a press fit anyway. I think I paid $25 or 30 for each unit.
My stand on smoke for my Japanese prototype steam locos is a result of two conflicting facts:
  1. The prototype locos were hand-fired with poor quality coal. They smoked grey to black, not white.
  2. My wife and I both have breathing problems, which would not be improved by contaminating our local atmosphere with anything that can produce visible smoke.
Combining one and two, there is no way I’m going to deliberately add to my lung congestion, even if someone does perfect a smoke device that can accurately simulate coal smoke. As for that possibility, it may happen - but my local oddsmaker won’t touch it.
Chuck (Modeling Central Japan in September, 1964 - with silent, smokeless steam locos)
