Hi Tom,
If you ever have a chance and can find those cars, they aren’t that expensive anymore. 12 cars looks so nice behind that engine, but even just the addition of the 2-car combine/diner set makes that train look so much nicer.
12 cars are a bit too much for the engine to pull if you use 31 radius curves though. However, it has no trouble at all with 42 radius curves & 12 cars.
I’ve occasionally removed the elephant ears from the engine, but doing so also does away with the white/red stripe, as it is all the same piece.
Without the ears on, the only portion of the stripe left, is under the cab window. This doesn’t look very nice, because I’m too attached to the stripe.
The ears are easily removed, if you ever get the “urge”.
Remove the main shell with the 4 screws underneath. Once you have the shell off, each ear can be removed by unscrewing about 4 screws from each side’s ear. (about 8 screws, total --12 including the shell’s)
I don’t have a permanent layout to invite you to see, this Sat., as I only run trains under the Christmas tree, due to a lack of room.
However, I might just drop you a line sometime if I’m up your way. Seems by your member’s site that you run trains all year?
PS: I’m using WebTV, which has a pretty slow processor & outdated windows media player / flash plugin.
It’s very likely I won’t be able to play your videos, but I’ll give it a shot.
We can play small size mpegs pretty well, however.
Webtv can only be upgraded by server side updates on msn, not by individuals.
Mark
