Ok, probably an obvious thing, but I was curious if this is common or not.
I’ve had this lil’ 2-8-0 HO Spectrum for about 4 years. It’s been packed back in the box (the nice black foam lined box) for about a year since I disassembled the test ‘L’ layout and am working on finishing a room at the back of the garage for a new layout.
I just finished building a manual turntable for the end of one staging yard and wanted to test the connections, so I got the old steamer out of the box.
Spectrum 2-8-0 DC (DCC ready). Using an old MRC Tech II DC pack. Track is perfectly straight and level.
She ran perfectly before it was packed away, but now forward is very slow: at full throttle she’s only going about the equivalent of 1/4 throttle. Reverse works fine, full sweep from dead slow to good top speed. On the forward selection sometimes the overload light will come on. Also I smelled ozone. NOT GOOD!
I did some searching here and found the thread about the RF filtering cap soldered at C1 (mine has a double cap linked together). I noticed that the red motor lead was tucked in very close to the 8 pin connector and some of the insulation was melted, but not all the way through, so I repositioned the wire. I then clipped one cap lead, moved the clipped end slightly to avoid contact, and took it out to the garage to try running again (shell still off).
This time, forward worked very slightly better until a plume of smoke began emanating from the center of the circuit board under the D4 resistor or whatever it is. Quickly shut off power and blew on the board until it co
