I have bent a 20’ dog bone on both ends to fit a 12’ long space. Soldered all the joints – another problem --some corrosion which makes for a lot of cleaning… I have two HO engines on the track, with a powered siding, so I can run them one at a time. They are very old… one I have had for over20 years --a Tyco “silver streak” style, and the other , an Anthern “blue box” of unknown age, from an ebay auction. My Tyco actually runs better, as it is fly-wheeled equipped and both trucks are drivers. I have a Rail power1300 which outputs 15vdc. The Tyco uses about 3/4 throttle to be at a nice speed. The Anthern uses the whole throttle and doesn’t move as fast. (another issue is a good cleaning.)
Now the problem… I have been thinking of putting them both on dcc, so I could have them both running at the same time. I experimented and ran them both with the current transformer. The Tyco was slower than normal, as expected, but the Anthern barely crawled around. Knowing that my transformer is maxed out with only one running, I purchased (because it was on sale at local hobby shop) a MRC tech7 which outputs 23vdc. Then I read on a blog that it may have too much and could b
Which Tech 7 puts out 23VDC? According to the specifications, the track terminals on all 3 models is 0-14.5VDC, which is just right for HO. 23VDC would be a model meant for G scale trains.
Some with disagree, but a 70’s vintage Tyco loco is probbaly not worth converting to DCC. By the Mid 70’s they were using really poor motors as a food company (Consolidated Foods) tried to squeeze every last dollar out of old molds and ever cheaper manufacturing plants. This is the era that gave us a GG1 with Alco C-C trucks under it, and a 2-8-2 that was no longer a 2- or a -2, because it was cheaper to leave off the leading and trailing trucks plus the assembly quality was so poor that it ran better as an 0-8-0.
The AThearn blue box loco - with a good tuneup they make good runners. If it’s the tan colored motor and not the black one, it’s worthwhile to convert to DCC. Still a little high on current draw, but it’s not horrible if tuned up. Plus there are many options to replace the motor with a modern high efficiency can motor.
Simply put the D/C analog controller takes the Alternating Current (A/C) 110v input and transforms it into Direct Current (D/C) voltage. Then the current is supplied to the track via a rheostat in the “throttle” or controller. The rheostat varies the D/C voltage output from 0v D/C to the maximum, typically 16v; with the Tech 7 23v D/C.
Eventhough the controller produces 23v D/C it’s the Amperage output that actually provides the oomph to move the D/C motors in the locomotives. If you have 23v D/C and only 1 Amp of power you won’t be able to run as many locomotives as a system that produces 16v D/C with 5 Amps.
DCC; Digital Command Control, is a completely different system. It consists of a controller and a power source, AKA “Booster”; some systems combine the two. The power source takes the A/C 110v and converts it to D/C, like the analog D/C system, but that’s where the similarities end.
The power to the track in the DCC system is constant.
The controller generates “packets” of information that are sent through the power source to the entire system (track). The decoders are assigned an address, by the user. The decoder only responds to the packets assigned to it, similar to how e-mail works.
The decoder then performs the specific function specified by the packet information; movement- -forward or reverse, lights, horns, etc., sent from the controller.
If you install DCC decoders in your vintage D/C locomotives and do not convert your pike to DCC they can (with a huge caveat) work. Most decoders have a dual-mode function; D/C & DCC operation.
If you have DCC equipped locomotives on a D/C controlled pike they will perform just like other D/C locomotives; when the t
Maybe it’s a misprint, but I see that the TECH 7 AMPAC 760 webpage indicates that the output voltage is 0-23 VDC, while it indicates that both the 700 and 780 output 0-14.5VDC. I thought the max voltage for HO motors is around 16V.
If your Athern locomotive barely crawls while your Tyco runs well, there is probably a problem with your Athern that needs to be resolved, even if you convert to DCC. Full throttle should be achieved with 12 V (see NMRA S-9).
Think of voltage as a pressure and the motor winding as a resistance (narrow pipe) that determines how much current (water) flows through it. Increasing the pressure will increase the current (amps), but other things such as dirty contacts (wheels) or
Wow… It’s a rainy day here in Oregon… so a good time for some “training”. I’ve been out messing with things… as Grandson says;;" Granpa, why does something always need fixin?"… but then he just likes to lay my old 027 track in various patterns on the floor, whether he runs a train or not… Anyway I’m glad so many of you were also spending a Sunday “training”. Thank you for all the information and reading material. I did not know where to start. I belong to an O-gaugers club – I joke to them that I am AC/DC… but their experience is whith their 0gauge controllers… and usually back away if I mention HO. I will spend some time digesting and reading. I did clean the wheels of the Anthern, and it runs better… no tune up yet.
As for the Tech 7 transformer, voltage was “reading the box”. It has some means to change the voltage so that the trains have “natural momentum” in slowing or starting… But it says it is for HO , N and other dc trains… Nowhere does it list amps. I have read about too much voltage… after I bought the transformer. I can return it if it is not going to do what I need.
Main Question: If both locos are suitable to convert to dcc, is the larger transformer better than using my old 15vdc? As I said, both trains run together , but are different speeds. the Anthern did better after cleaning, but still slow. If the transformer with its 23 max vdc would make a good base for dcc, then I should keep it . Otherwise, I should return it.
Main point is that I will read all the linked information to better understand what possibilities I have. I thought it would be cool to have both runningn at the same time, and I think the grandson would get a kick out of it… and more of a challenge when running the HO’s. He’s more of the 027 operating things type.<
you seem to be under the impression that you can use a DC controller for DCC. You can’t.
DCC controllers have their own power sources. The DCC command stations communicate with decoders by inverting the polarity of the track voltage. DC controllers, such as the MRC 760 are not designed for DCC.
South Penn’s suggestion that you could use the power pack for layout accessories is correct, but in your case the 23 volts will likely never be used. Most layout accessories are operated on 12 volts or less. If you were to accidently apply the whole 23 volts to your 12 volt lighting system you would probably burn out the whole lot in one big flash.
I would take the MRC power pack back and get a refund, and then use that money to buy a 12 volt power supply. EBay has current offerings for dedicated 12 volt power supplies for less than $10.00
Late 80’s/early 90’s, Tyco switched to using Mehano-produced locos, pretty much the same as the contemporary AHM/IHC models - they actually did have a can motor and 8 wheel drive. Much superior to Tyco of the mid 70’s, but too little, too late.
At the time, mid 80’s… we were in Alaska, and very limited offerings… it was more… I want that one Dad… I got a Santa Fe war bonnet schemed passenger, and he got the slilver streak… but later paiinted it… just becasue… so I don’t know what it was.
If it is not possible to control both trains so they meander around the pike without running into each other… I’ll stick with what I have. As for voltage… I will have to check. 23vdc transformer package says “HO, N and other dc”, but 23 seems excessive for trains that normally draw 15, so I will return it… It’s not a good deal, unless it suits the purpose.
I really don’t want to put money in electronics right now, so not going dcc or souind for that matter is just fine. Thank you for a great discussion topic. This old man never stops learning things… the wife would wonder why I even thought of this as I have plenty of other things to ponder… like getting ready for winter rains… But the nice thing about rain is if you make a path, it will keep going. Snow on the other hand, needs a large place to pile… sure don’t miss that.
Thanks again for an interesting day’s topic… Richard M.
I finally got an answer back from a tech about the mrc tech7… he said it does 23vdc “without a load” , but once a train is on, it goes back to about 15… so it’s sales gimic. But I did hook it up to the track with my two locos… I have a block at each end of the layout. Both moved much faster than with the other transformer… (They had been moving, but"crawling".) Bottom line, this transformer has more amps, I think, so the locos can move better when both are running. I haven’t moved the throttle more than3/4 and speed is nice. So I’m happy, and my grandson can help with on and off blocks and watching for derailments… Many thanks to all who gave me info… but I’ll leave DCC for the future. My old trains don’t need the upgrade.
If you are really concerned about moneyim.pretty.certain youll have a small layout. DCC maynot.be.right for you. You could pick up a bachmann EZ controllee for 40 on ebay. That has powee and.controllee. you could use your old supply.for accessories. But youll likely have to scrp your engines. The tyco silver streek is likely pancake driven. And that old athearn bb will require a lot of tinkeeing.to.run well if it has sat. You can get two mantua.clasaics for 50 each plus 20x 2 for decoders. Or you can get bachmanns with dcc installed already that look better then the old bb tyco for.60 each. Typed on phone
I have four of these meters. Good for checking the car electrical which is 12 vdc. Even around the house if you can work with mains power. They bounce if dropped.
