soldering Gaugemaster solder pads
I am using Gaugemaster PM1 point motors to operate my 3 Peco 3 way insulfrog turnouts. Can anyone give me some suggestions on how to solder to the PM1 solder pads?
Thanks
Bob D
BOB,
I recommend, 60/40,Rosin Core solder,it’s about 1/16 diameter,either,Oatey,Kester,Radio Shack used to have Oatey…I’m guessing,the pads are already tinned,if not,I would recommend that you tin them and tin the wire,that you will solder to it…
Cheers,
Frank
BoB,
I forgot to add,hope you have a small watt,soldering iron,pencil tip or small chisel tip,about,25to40 watt,would be fine,stay away from a big soldering gun if you can help it,way too big for the pads…
Cheers,
Frank
Hi Bob,
Any fine tiped / low watt iron’ll do on a Seep, check you use the right tabs, not the accsesory ones and you could do with using a CDU as well
Be in touch.
pick…
