This is definitely for Tree. Tex rail has installed their RR antennas for directional out put. The only question is are any other RRs already doing this in many urbanareas ? The tech is not exceptionally hard.
The antennas and ‘improved shacks’ appeared around here [ South of Wichita, and down towards Wellington,Ks- Eastern part of what could be the BNSF’s Southern T-con.] about Summer before last.] This area woulld pretty much be considered urban, and maybe, a little rural? This part of the line, it has been mentioned by some of the local railroader’s, hosts numbers around 60 trains a day(?).
Directional antennas make a lot of sense when you have a reasonably straight right of way. The article was correct in stating the transmit coverage improved along the ROW, but left out that the directional antennas also reduce interference to the base stations’ receiver.
FM does have a “capture effect” in that a signal a few dB stronger will comletely block a weaker signal.
Already a common practice, actually. Never mind the congestion factor (there are about 200 railroad frequencies available, although crosstalk can be an issue if you get them too close together), it makes sense to focus the signal so base stations can be further apart and/or use less power.
As noted in the article, railroads are linear, so why waste energy sending signals to places they don’t need to go?
