my wife gave me an mth fa2 aa diesel for my birthday. i tried to follow the instructions of throttling up (not past 10 volts as the manual says)and slowly throttling down to off and back on again to get the engine out of reset mode into forward mode. i can’t get this thing to do anything but make 2 bell sounds, throttle up and sit with it’s lights on. it won’t move.
It sounds like your are operating your engine in the convetional mode (non-command).
Turn your power on and the throttle up to about 10 volts, then press the direction buttone and see what happens. MTH engines start up in nuteral. You have to press the direction button for them to move.
OK this is an old PS1 engine from 2000. The battery is past it live. Buy an new battery, charge it up and replace the one in there. You could also repace the battery with a BRC unit. http://www.jandwelectronics.com
YOu can TEST your engine with a standard 9 volt battery. But do not leave it in there as it can not withstand the charging unit.
Certain MTH locomotives can get their “brains” scrambled if one attempts to operate them with a low charge in the battery. MTH offers a chip to fix this. MTH and some of their dealers have them. Some dealers will do the “unscramble” for you if you take the locomotive to them. Call ahead and ask.
Also, certain modern transformers, notably the Lionel CW-80 I believe, are simply not compatible with MTH PS-1 locomotives. If you have your MTH owner’s manual, check it to see whether your transformer is compatible.
Others on this and other forums know much more about this than I do. Keep trying and report what equipment you are using and what “fixes” you have tried. Someone will get it right.
well all i have to say is thank you all!!! it was the battery. i plugged a regular 9 volt in and it ran like a champ.i’ll be buying a new mth battery tomorrow.
I used a CW 80 for short time with two PS2 engines, one steamer with a 3 volt system from a starter set would run OK, another older diesel with a (I think) a 5 volt board would sometimes just sit on the tracks a blow the horn and not move. I couldn’t get any of the conventional PSA sounds or or couplers to work.
Well so far the first engine is working ok. It is a 4-8-2 Mohawk Texas & Pacific Steamer made I believe in 1997. It has the proto sounds. I thought it had the Speed control option too but none of the paperwork says anything about it and it doesn’t maintain a constant speed at all. It slows down considerably in the turns and the chuffing sound isn’t nearly as good as my Lionel engine but man does it smoke!
Yep that is the engine I have. A beauty for sure. I see You pull a passenger line with your engine. I have to get the passenger cars yet. Any idea where I can pick them up at a decent price? Is it possible to update the sound system by using the update downloads? so am I correct in that this particular engine does not have the speed control on it? I have a 2-8-0 Pennsylvania coming and it is a 2005 model with proto sound and it states it has the speed control option. Does this option require a special transformer of anykind? The one I have coming came out of a set that was sold with the Z1000 transformer so I’m guessing it shouldn’t need anykind of a special transformer. I do appreciate the knowledge here! Thanks guys.
QSI was the mfg. of the sound board for MTH up to 2000 when MTH changed to PS2. I believe QSI is still making sound board. So if you want improved sound board, that would be your best bet.
You have any idea how to contact them? Did you get your T&P set complete or individual pieces and put it all together. The rechargable battery is bad in my tender and I am presently “Temporarily” using a 9V, could I use a rechargable 9V battery to replace the one that MTH installed or do I have to get a specific one from them?? Any idea what they cost?
