Some turnout wiring questions
A Bit of Turnout Wiring Help
Hi, I was hoping some people here could help me out with some wiring questions. I’m about to start wiring up my little 5x9 layout. Going to be buying an NCE Powercab for train ops and I think I have a decent grip on how to do the wiring for this - seems pretty straightforward.
I’m also going to be wiring up a set of 10-15 tortoise switch motors. My ultimate goal is to have a central control panel for all the switches, with bi-polar (red/green) leds indicating the switch direction. I’m also going to be using the tortoises to power the frogs of my Peco electrofrog turnouts.
My main question is this: I have an MRC Tech II Loco-Motion 2500 power supply from an old DC layout I ran years ago. Can I use this as the power source for the turnouts and other accessories? The instructions on the tortoise says that you can’t use more than 12v of power across them. This supply outputs 20v DC. It actually has 3 sets of terminals in the back - Variable DC (20v), Fixed DC (20v), and Accessories (16v AC). I was experimenting a bit with my volt meter last night and measuring the outputs. From what I understand, the variable DC output changes as you move the throttle around. I was able to set it to 12v, and succesfully wired up a test motor with a DPDT switch, but I was afraid to use the other outputs or crank up the power on the variable one. I didn’t want to burn out the motor.
What would be the best way to use this power supply for my purposes? Do I have to use the variable DC output and just make sure nobody accidentally turns up the power? Or is this dangerous to do? I don’t want to blow out $150 of switch motors! I would rather use fixed DC or AC outputs of possible.
Second Question: Trying to understand how the powered frog works exactly. All of the track on my layout will be powered by the main DCC bus. If I have the tortoise wired up to my DC power bus, and then power the frog from there, does this mean the frogs
  1. I don’t know whether the MRC can hurt the Tortoises if turned up all the way. Worst case voltage is full power with only one Tortoise and its LED drawing current. I used the Circuitron 12v walwort which can power 30 or so. It is suggested to put a fuse to protect your power supply in case you make a wiring mistake.
  2. EDIT: For clarity, what turnouts will you be using? Oh, I see Peco Insulfrogs. I think these frogs can not be powered. Did you mean Electrofrog?
http://www.wiringfordcc.com/switches_peco.htm
If you get a turnout with isolated metal frogs (unpowered until you feed track power to the frog) the frog is isolated from the rest of the turnout but metal and thus need to be left unpowered (dead) or provided switched DCC track power (not DC Tortoise power) according to the switch diretion. The frog needs to be the same “polarity” at all times of the rails of the current route using the frog. A feeder is attached to the frog and connected to one of the Tortoise auxiliary contact sets. These aux sets (there are two) are switches independent of the DC switch power that moves the Tortoise motor. You would run track power (each polarity) to the aux inputs and as the Tortoise is switched the aux output switches the frog from one track polarity to the other. More here:
http://www.wiringfordcc.com/switches.htm#how2wire
If you don’t have the Tortoise instructions, download same on the Circuitron site.
  1. There are former threads that show the bipolar LED wiring to the Tortoise DPDT toggles. I’ll see if I can find one. EDIT: see the folling thread where Gandydancer posted the diagram you need. Sorry I can’t figure out how
That’s exactly what I do to power switch machines. I use an old power pack with the switch machine bus connected to the variable DC output. I adjusted the “throttle” to ensure optimal performance from the machines. A Tortoise isn’t as finicky about voltage as the instructions make it sound; you can exceed 12V a bit without harming one, although I wouldn’t consider using the full 20V output.
If you’re concerned about someone accidentally turning up the variable DC, you could probably just remove the throttle knob. There should be a set screw or two holding it to the shaft. I’d also mount this power supply somewhere under the layout or otherwise out of view so nobody can get curious and mess with it.
Paul - yes sorry, I meant to write electrofrog. I corrected my OP. I see now, so the tortoises acutally get two sets of power - one for operating the motor itself, and another for switching the polarity of the frog using the DCC bus. I probably would have realized that shortly!
wp8thsub- That’s a great idea about removing the throttle control I will see if I can do that. If I wanted to use the fixed 20v, can I buy a DC/DC converter to get it to output 12v? I also didn’t realize that 12v power supplies are actually pretty inexpensive, so maybe it’s worth just buying one then. I did want to get some use out of this old power pack though.
Just curious - what is the main difference in usage between the DC terminals and the AC Accessory terminal? When would you want to use one over the other? I should really know the answer to these questions since I studied college level electrical engineering for two years - But I guess this is why I swithced majors :slight_smile:
I did a test hook up with an old MRC Tech2 Railpower transformer to power Tortoises. Connected the Torti to the Variable DC and turned the throttle up to a measured 9 volts of output. It operated the Torti okay, but with the switch mach. emmitting a continous and much irritating buzz.
Went with Torti instruction sheet and used method 2, Bi-Polar DC with SPDT toggle switches and two 12vDC 3A desktop switching power Supply. Driving 24 torti, works great and no buzz.
regards, Peter
Yes, Elmer’s picture is perfect. I’ll link it in for everyone.
This shows a pair of 2-lead LEDs. They can be either single-color, in which case one will light for one direction and the other will light for the other direction, or they can be bi-polar, and there will be one green and one red, both always lit but with the colors changing with the direction of the turnout.
You can use the variable DC. I would suggest building a shelf beneath your layout for it, so the variable knob is not easily accessible. I prefer a sligthly lower voltage for my Tortoise machines, more like 8 or 9 volts, because it slows down the motion of the points.
The auxiliary contacts on the Tortoise are set up as two single-pole, double-throw (SPDT) toggles. This is the diagram from the Tortoise instructions, for reference:
These SPDT toggles are completely independent of the drive power on terminals 1 and 8. For powering frogs, connect a green wire (because use of consistent wiring color codes is a good idea, and frogs are green) to the center post of one SPDT (posts 4 or 5) and then a pair of track feeder wires from your bus to posts 2&3 or 7&8. I use a meter to get the pairing right, or you can clip them together and run an engine over the powered frog. If it shorts, reverse the feeders.
The fixed DC terminals on the MRC power packs are for hooking up one of their cab controls - which are the throttle and direction switch part of the power pack without the AC line voltage transformer. They take a fixed DC input and produce variable DC that can be used with cab control wiring to run a second train. The AC side is for powering twin coil switch machines and runnign things like structure lights, since light bulbs work fine on AC or DC.
If you go the route of adding series LEDs with the Tortoise motors for indications, you will reduce the voltage to the Tortoise motor by the LED voltage - for red and green this is about 2.7 volts. This is actually good - while the specs on the Tortoise say 12 volts, the sweet spot is really around 8-9 volts, they run quite a bit quieter at the lower voltage, yet still have plenty of power to move the points. So starting with 12 volts, and adding series LEDs to indicate position, leave the Tortoise with just over 9 volts, so you get indicator lights AND a better runnign Tortoise.
Peter - I noticed a buzz as well. That was going to be one of my follow up questions. This is my first time working with these motors, wasn’t sure if this was normal or not. What causes that exactly?
The buzz is probably because the variable DC has pulse power - what model MRC power pack do you have? If it has a pulse power switch, make sure it’s off. If it is of the automatic pulse type, there’s not much you can do. A 4700uF 35V capacitor would probably smooth the pulses out - however two things - electrolytic capacitors are polarity sensitive and will can literally explode if run backwards, so check the polarity and also never touch the direction switch after it’s hooked up. And applying filtering will raise the voltage a bit, so check the voltage you are getting after connecting a capacitor. You might have to turn the speed knob down a little.
Probably easier to just go get a 9V or 12V (12V if you are going to add the indicator LEDs) DC wall wart. A 1 amp one can run over 60 Tortoises. Or you cna get some inexpensive 1N4001 diodes and wire a string of them in series. Each one drops .7 volts. Connect to the 20V DV fixed terminals on the pack. Of course, this needs a string of 12 of them to get down to 12V - again, the simple DC wall wart is the easiest option.
H, My MRC powerpack is an old Railmaster 2400 with a pulse power switch. Just for grins I hooked it up to a Tortoise mach a bit ago.
Randy is correct about the cause of the buzzing being the pulse power, the Torti buzz is only with the pulse power switch on, buzz stops with pulse power switch off.
good luck and regards, Peter
The model is Powertech II - Locomotion 2500. I don’t think it has any control over the pulse.
Can someone recommend a good power supply for what I’m doing? Would need something that can power 20-30 tortoises and accompanying LEDs. If I have other accesories in the future, like lit structures, etc, would be nice to use the same supply as well. Thanks for all the help everyone.
Tortoise runs on DC. LION prefers to use them with a common ground and then use a SPDT toggle to select between (+vdc) and (-vdc). You only need ONE wire to each turnout that way (and one ground bus around the layout.)
Best Advice: Throw out the instructions that come with the tortoise, and use my instructions…
ROAR
Here’s one, 12V, 2amp, and it’s regulated - so it puts out 12V (or at least really close) over the whole laod range
http://www.amazon.com/Power-Adapter-2-1mm-Regulated-Supply/dp/B00DGG7E36/ref=pd_sim_sbs_e_5?ie=UTF8&refRID=1WG2AFV7MW9D3X694676
and it’s cheap. Plenty of power for 20-30 Tortoises and lots of LEDs to light up buildings and streetlights.
Tortoise plus the series LEDs draw no more power than the Tortoise alone - 15-18ma.
Since wall wart power supplies like this typically have a fusible link inside to keep from burining down your house - if you short the output, that’s usually it for the power supply and you have to get a new one. So what you should do with something like this is add some fuses before the Tortoises and the building lights. That way if you short something, or attach too many structure lights, the fuse will blow and not the power supply. I’d make two circuits, keep it simple, each with a 1 amp fuse. One feeds the Tortoises, one feeds the other lights.
H, A sketch of what’s working well for me, taken from the Tortoise Instruction sheet, but powering switch machines only. The single red/green bi-polar LED saved panel space, no resistor needed, torti takes care of that. SPDT toggles and buss simplifies wiring too.
Of course there is the cost of two power sources, think I paid about $15 each from All Electronics. I’ve shorted the circuit briefly a couple times, lucky no harm done, but maybe I should think about fuses.
I also have all my layout power hooked to a master wall switch, when train time is over I kill the switch, piece of mind thing.
Regards, Peter
MisterBeasley - The diagram is extremely helpful. I just have two questions about it. Seems I need things spelled out exactly for me. :0
You said that when the polarity of the switch changes, the bi-color LED will change. If I use a 2-pin bi-color LED, what do both pins get attached to? In the above diagram it looks like there are 2 LEDs which I guess is slightly different.
My second question - If I wire it as above, would I have one DC bus running through the layout? I plan on having a central control panel that houses all the LEDs and toggle switches - and I imagine the power supply will be in there too. How can I set this up with the least amount of wiring? I’m trying to avoid a situation where I have 4 or 5 wires going back and forth to the panel for each turnout. I was imagining having one DC bus running through the layout, and then having each turnout wiring assembly tap into it - but I’m not sure how the toggles and LEDs come into play then.
Thanks!
H
Yes, this diagram does use 2 LEDs, but you can simplify it with just 1 LED in the same place if you prefer.
If you’re going to have a central panel, they you will need just 2 wires running from the panel to each Tortoise machine. In the diagram, the power supply, DPDT toggle and LED or LEDs would be at the panel, and only the 2 wires need to run to the Tortoise from the panel.
If you are planning to power the frog from the Tortoise, that can be done locally using feeders from your track bus and a single wire from the Tortoise to the frog.
Ok, so if I wire it in this way, I won’t really have a central DC bus running through the layout, right? Each motor would just have it’s own set of two wires running back to the panel area? I was thinking that there would be a central DC bus that each motor assembly would tap in to, but it makes sense that at least some wiring would have to go back to the panel, per switch.
And for the LEDs, do I need any resistors in this configuraiton? I can never get that straight. Should have paid more attention in my engineering class.
Thanks again,
Wires like Mr Beasley’s diagram? yes, 2 wires to each switch machine - they can be pairs out of phone or netwrok cables, the current is very low. No central bus other than inside your control panel to provide the inputs to each toggle switch.
No resistors needed. Things in series share current. The Tortoise motor is 15-18ma, thus LEDs wired like that also get 15-18ma. Which is well within the safe range for the LEDs.
I got it now. Just ordered a power supply, and a few LEDs and switches to experiment a bit.
On last question on this topic - how do you guys distribute the power from a power supply like this? Seems my power supply, and all of the wiring to and from it and the toggle switches will all be located mostly inside my control panel. To avoid a mess of wires, I was thinking of wiring the power supply to some sort of distribution block, and then attaching all the wires from the switches to the block - either by screwing in, with spade connectors, etc.
I can’t seem to find a block or strip that would allow me to do this? Most of the ones I see are barrier strips, that isolate each connection from the next. Do I need to use one of these with tons of jumpers, or is there a better solution? I will have about 15-20 turnouts, so it will be a lot of wires inside that control panel and I’m trying to figure out the best way to keep it neat and tidy.
Thanks again for all the help.
Run a bus line from the power supply along the bottom of your control panel, and have all the wires to the switch motors exit at the top. Or vice-versa. Drop two wires from the toggle to the bus for the input side of the circuit. This will keep the input wires and the output to the switch motors seperated and looking neat. Tag the wires to the switch motors with labels, and cable them together with velcro wire ties (not the plastic kind - you generally have to cut those off and use a new one if you need to change anything. The velcro ones, if you add another wire, you just open up and re-wrap). There are also anchors that you can screw into the back of the panel to hold these in place, so there is a neat line growing ever thicker going across the back of the panel, and you have only one bundle of wires going out to the layout. This is why you need labels, , or alternating wire colors, and the velcro, so you can hook up one at a time but in the end have everything cabled together looking neat. If your panel swings up or down, or swings to the side, then the wire needs to exit near the hinge and have enough slack so that you can open the panel fully.
