Read the courts opinion…
First defect is, of course, the fact that the part of the deposition concerning NS safety record was allowed to be shown to the jury precludes a mistrial, which is odd that NS failed to request.
The sitting judge should have pre-viewed the video.
Two, although not argued by NS, no where does it specificly state the land belonged to NS, and the statue on vegatation, as supported by the review judge, is designed to prevent injury to rail passengers, not motorist.
Three, the portion in regards to the adquated crossing protection was reversed on appeal, because federal law pre-empts local law, and the sight triangle nonsense likewise was dismissed, as it dosnt pertain to railroad crossing, but is intended for roadway intersections, not railroad grade crossings.
Fourth, the opinion states the deceased lived within a mile of the crossing, and used it at least twice daily, which indicates he was aware of the crossing, and aware of the danger associated with it.
Had the estate been able to prove that the deceased had contacted NS in regards to the problem, it would have been a cut and dried case.
Note that in the original suit, the estate argued that the train failed to sound it horn long enough to give warning, but note that both the court, and the appeals judge found the engineer sounded the horn for a constant eleven seconds before impact, and that the auto was traveling 20mph.
Both indicate that the engineer could see the auto, for at least 11 seconds.
If he could see the car, the car could see him.
This portion of the findings was reversed on appeal.
So it ended up being a case of a faulty interpretation of a old state statue, intended to protect rail passengers from being injured by trees in case of a derailment, versus a applicable comprehensive statue designed to provide
clear veiw sight lines at grade crossing, (which most states have yet to address).
Count on
