I tried wiring this to my SC-2 like in the photo in fig 2 below but when i tried prorgraming it nothing worked on the SC-2 it shows A &U 7-20VAC power supply and from terminal strip to A&U on power supply for lights and accessories what am i doing wrong it s like there was not getting enough power for the fire station i could hear the motor
I know this feeling of despair – wires are connected, yet the desired results aren’t quite happening! Although I can certainly walk you through the ASC version of this scheme wire-by-wire (I’m currently using it on my layout), I’m much less familiar with the SC-2. If you can hold on tight for the evening, I’ll see if I can contact the author of the SC-2 tip and alert him to your trouble. Help is on the way.
Twenty-two AWG if your transformer’s overcurrent protection trips at about 3 amperes or less. Eighteen AWG if your transformer’s overcurrent protection trups at about 7 amperes or less.
My lionel SC-2 is powered by track power can i use the CW-80 80-Watt Transformer by running wires from the fire station to the terminal strip then wires from theterminal stripto A and U on theCW-80 80-Watt Transformer but confused on the back of theCW-80 80-Watt Transformer it shows track A and U/Accessory B and U does this mean i connect wire from the terminal strip to B and U on the transformer i am trying to do this right
