Hi everyone. It’s been a long time since I’ve been on here. And where else better then to ask you all for help. I have a Canadian National SW9/1200 switcher that I would like to have a sound decoder in. I’m modeling 1955 if this makes a difference. I haven’t been able to find a decoder that would work. Any help would be greatful. Thanks.
What brand ? What scale ?
The time frame you’re modeling makes no difference, but the brand of locomotive and scale sure does.
Ya sorry about that I should of mentioned that it’s a Proto 2000 (Life Like) and it’s HO scale.
Do you have a metal milling machine or know someone at a machine shop who can mill away enough of the frame to fit a speaker and decoder without getting into the motor and gearing? P2K models have very little room for even a simple motor control decoder unless it’s a new “DCC Ready” model. Even then, finding room for a speaker can be a real challenge.
An alternative would be a new Broadway Limited Paragon2 switcher that already has DCC/Sound factory installed.
I’ve done several installs on these exact engines for customers. You do not require a mill/shop to do a sound install. The frame is removable from the motor. Using a band saw equipped with a metal blade, or hacksaw and careful measurements you can install easily with two mini oval speakers with enclosures. Two quality sound decoders can be used; either the new QSI Rev U/A or the Lok Sound micro. Erik Fiske
LokSound Micro, decoder and speaker installed in the cab.
David B
Thanks for the help guys. I do know of some people that could mill out part of the frame for me. Or I could try Erik’s suggestion. I will look into the LokSound Micro. Thanks again everyone.
