Looking for suggestions for a sound decoder installation in a Spectrum HO 70 tonner with single motor.
The loco had a Cooper-Bessemer 6 cylinder, 4 cycle diesel. I will be using the LokSound micro with the speaker that comes with it. LokSound does not seem to have a similar USA sound but I have no knowledge of diesel engines. The only thing I have been told is, do not use a Alco sound as many know what Alco’s sound like so they must have a peculiar characteristic sound.
Search for Wolfgang’s posts on his ‘critters’. He’s put sound in various small locos that don’t use more typical GE, Alco, or EMD prime movers. Not sure which sounds he used. Loksound has a few diesel motor car sounds that should work. For casual visitors, the Baldwin would work because it’s different enough from anything you’re likely to hear these days, but liek Alco, Baldwin diesels have a distinctive sound that says “Baldwin”.
A little more progress. Again, PC board and weight not used. I will add weight in different spaces before final install of shell. I have some metal for weights that melts at about the temp of boiling water to make my own weights. I use some styrene walls to make small containers for different size weights. Lead shot works also.
I found the sound from the decoder I mentioned to be quite like some You Tube videos of full size 70 tonners. I have a couple I saved made near a loco. One the engine is idling, the other is a actual Cooper-Bessemer 660 HP diesel starting and idling. That is the main engine that came with some 70 tonners.
The Baldwin VO6 sound in the decoder was also a 660 HP diesel about the sam era.
The metal melts at the boiling temp of water. I put the metal in a small sauce pan. I put that pan in a little larger sauce pan that has water in it. When the water boils, the metal melts and I carefully pour it into the plastic forms while watching the scale. I found the scale on ebay for about $20…00, free shipping.
I have seen this metal sold at MRR shops in the past but I bought my stuff from McMaster-Carr some years ago for a different project, an industrial supplier that will ship to individuals.
My only comment is that the loco starts moving before the sound ramps up. Perhaps you could play with the momentum a bit so that the motor is slower to respond and the sound comes on before the loco moves. Just a suggestion.
