I have a brand-new Spectrum Decapod w/ DCC+sound (2-10-0) I was fooling with it in JMRI (A decoder program) and I messed up the factory sound settings, and I wish to reset them.
The Decoder is a Tsunami Meduim Steam decoder.
So HOW do you reset your locomotive completely back to it’s factory setting?!
For my BLI (quantum sound) locomotives (and stock cars), I wave the magic (magnetic) wand over the location shown in the user manual. I can never remember where this is from loco to loco so I always have to look it up. For my Genesis 4-6-6-4 with the MRC Brilliance decoder I still haven’t figured it out. In that case reading the manual is worthless. BUT I’ll bet your Tsunami is totally different.
I dont know Tusnami Decoders but QSI decoders use a 3 step Reset procedure using CV Values.
If your decoder supports this reset method, you MUST… MUST remeber this:
Have the engine BY ITSELF on a short peice of track. This reset procedure has the ability to reset ALL decoders on the network I think… but check your manual.
As with many decoders, a Tsunami will reset with “eight to eight” (set CV 8 to a value of 8). This may be done either on the program track or the main, and won’t actually change what’s in CV 8 – it’s just an instruction to reset everything.
Click Support, then Manuals. Note the TSU Tech Reference is a biggie – 104 pages. I wouldn’t suggest starting there, but take a quick look. You’ll want to refer to it later. You should probably start with the Quickstart, then the Steam User’s Guide.
There’s a whole passel of info in these manuals, but they’re also very complete. Don’t be discouraged if some of the topics are a bit mind-boggling – just work at a bit at a time, and they’ll eventually make sense. And don’t hesitate to post questions here. You won’t believe how much you can customize these absolutely supurb decoders!
I think TZ is dealing with a MRC 1631 Brillance decoder, in which case, changing CV1 and 29 should work. MRC also uses CV125 on newer decoders to affect a reset to factory settings.
